jdm b20b spun rod bearing = burnt rod, crank cap and crank???
Old Jun 23, 2005 | 09:23 AM
SQ is the SQUAD's Avatar
Default jdm b20b spun rod bearing = burnt rod, crank cap and crank???
i picked up a used jdm b20b long block off of ebay ($112) for my build. the seller said i had a bad rod bearing in the #1 cylender. i dident care seeing as i was sending the block out to get re-sleeved anyways. i am thinknig of going with eagle crank and rods but i was wondering, will i need to replace those crank caps also? is it normal with a spund rod bearing for the stuff to burn black? the other 3 cyl look normal and all the cly walls look ok.
also is it worth saving this crank and rods, i know there prob junk but do they have enough value to try to repair?
Old Jun 23, 2005 | 11:57 AM
Default Re: jdm b20b spun rod bearing = burnt rod, crank cap and crank??? (h0ndavtec)
no one knows?h
Old Jun 23, 2005 | 03:29 PM
Rocket's Avatar
Pictures will help. Hard to tell the "degree" of black or burnt.
B20B head is a good find.
kornerk12
Oct 8, 2007 05:08 AM
eg4life1202
11
Jan 14, 2007 09:17 AM
VRD^don
Nov 2, 2004 02:28 PM
hatchedzex
Oct 4, 2004 11:40 AM
S13 slide
Dec 2, 2002 05:54 PM
