Head Part Swap
I have an H22 adn i bought S2S2 cams w/ complete valvetrain.....i dont wanna pay anyone to do this if it is fairly straight forward...how hard is this to do, how long would it take?
thanks in advance
thanks in advance
I am guessing you do not have the correct tools valve spring compressor ect. since you have to ask is it straight forward. I would have it done buy somebody capable and let it be over with its very easy to kill a motor only takes 1 improperly installed valve keeper to drop a valve
me and my friend put skunk2 valvetrain and cams in his prelude one weekend. it is fairly straight forward, it just takes time doing everything. just make sure you have a service manual and all the tools in hand before you start! good luck.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AirMax95 »</TD></TR><TR><TD CLASS="quote">well, the head is almost completely disassembled (still bolted to block). I can get ahold of a spring compressor......
how long was the job, how did it come out</TD></TR></TABLE>
I would defiantly remove the head then. Its really not that badd a job if you know what your doing. It can be done with the head on the car using air in the cylinder.
Just take your time and do it slow and correct since its your first time I would say with the head off the car a few hours goodluck
yeah, the motor is not in the car......i'm 3 hrs away from it (im in school, its at moms house). when i get enough time I am getting a truck and bringing it down......
thanks for the replies....I cant wait, the F22 is boring me more and more
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrettyLude »</TD></TR><TR><TD CLASS="quote">you might want to consider changing the timing belt, balance shaft belt, and both the crank and cam seals too, since its convenient</TD></TR></TABLE>
Cant forget the oil pump or all your hard work will be for nothing
just take it to a local headshop. Pull the head bring them all the parts and ask for a pressure test, resurface, and check for warpage. Im sure they could also give you a little port job too. All in all should only set you back about 139-149 bucks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AirMax95 »</TD></TR><TR><TD CLASS="quote">as far as the timing belt goes, with the mods listed in my sig, should I use the OEM parts or use a Greddy Tbelt set? </TD></TR></TABLE>
oem timing belt, with manual tensioner, the greddy belt is overrated
oem timing belt, with manual tensioner, the greddy belt is overrated</TD></TR></TABLE>
Agreed I have seen 3 greddy belts on h series 2 were fraying badd ofter about 3000 miles and the other snapped bent all the stainless valves in the head after only 2100 miles on turbo h22a4. I say honda personally
the work should take a couple days from start to finish. since your engine is already taken apart, you should be able to finish in a day with the right tools and some help. i agree with the timing belt, crank seal, balance shaft seal, balance belt, and cam seals being replaced. just take time and make sure you have a helms!
Anthonyl469
Mar 13, 2003 11:25 AM
