Will i need a new oil line kit?
Old Jun 23, 2005 | 08:26 AM
JDMTurboCivic11's Avatar
Default Will i need a new oil line kit?
Ok right now i have a small t25 turbo set up, i just ordered my new setup with a t3/t04e Garett. Now am i going to need new oil lines?
Old Jun 23, 2005 | 12:31 PM
Default Re: Will i need a new oil line kit? (JDMTurboCivic11)
bump
Old Jun 23, 2005 | 12:41 PM
TunerToys's Avatar
Your T3 will have different oil inlet and outlet connections.
The T25 will normally use a 7/16-24 Inverted Flare, and most T3s use 1/8NPT
The T25 Drain flange is 44mm bolt centers, and most T3s use 50.8mm
If your braided steel feed line is -4 or -3 AN, then you'll just need to replace your inverted flare fitting with a 1/8NPT to -4 or -3 AN fitting.
Your drain flange will need to be replaced, and depending on how your drain line connects to the flange, you may need to replace a fitting between your drain flange and drain hose.
Craig
If you can send pics of your setup, I can let you know exactly what you'll need.
sales@tunertoys.com
importboi22
Oct 4, 2004 05:45 PM
untitled
Apr 6, 2004 04:51 PM
harryg
Dec 2, 2003 12:02 PM
Rory Breaker
Oct 28, 2003 02:43 PM
M.A.R.C.
Jun 20, 2002 05:33 PM
