alarm and power locks?!
Ever since i've had my 94 Accord it had a viper alarm. Just want to know if I switch the alarm over to my other car, is there still a way to use a remote for unlocking/locking the doors? I'm not sure if it originally came standard this way or if the alarm is just allowing the use of a remote. Any help or suggestions is appreciated. thanks!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BDogggUT34 »</TD></TR><TR><TD CLASS="quote">Ever since i've had my 94 Accord it had a viper alarm. Just want to know if I switch the alarm over to my other car, is there still a way to use a remote for unlocking/locking the doors? I'm not sure if it originally came standard this way or if the alarm is just allowing the use of a remote. Any help or suggestions is appreciated. thanks!
</TD></TR></TABLE>No you can not use the remote to lock and unlock the Accord, the remote is for the Viper alarm, and the door locks have been hooked up the alarm to give you key less entry, once you remove the alarm, the key less will no longer work, if your Accord came with key less entry, you will have to get the Honda remote, you will have to find out if it was an option on your Accord, if not, you can get a cheap key less entry, or even a cheap alarm, [under $50] and install it into the Accord, with the alarm, just don't hook up anything except the door lock outputs.
94
94
