Alpine alarm?
Old Sep 10, 2006 | 12:31 AM
Mysterious's Avatar
Default Alpine alarm?
My niece was playing with my remote and pressed the buttons. I don't know what she did but now my alarm is not functioning correctly. The alarm doorlocks lock when it is armed but does not unlock itself when I unarm it. Also, when I arm the car, about 5 seconds later it beeps like if a door was open. Does anyone know how to fix this problem? I.E reset it to factory setting. I've tried to unpluging the brain but it is probably saved onto the alarm itself. Thanks
Old Sep 10, 2006 | 03:51 AM
audioroach's Avatar
Default Re: Alpine alarm? (Mysterious)
can you supply us with the model number on the alarm brain?
Old Sep 10, 2006 | 06:57 AM
fcm's Avatar
fcm
Old Fart
Default Re: Alpine alarm? (audioroach)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by audioroach &raquo;</TD></TR><TR><TD CLASS="quote">can you supply us with the model number on the alarm brain?
</TD></TR></TABLE> Ditto that, although there is nothing you can do with the remote that would keep the doors from unlocking, also if the siren chirps 5 or so sec. after arming it indicates the that the hood or trunk/hatch is open. 94
Old Sep 10, 2006 | 08:59 PM
Mysterious's Avatar
Model number is SEC 100S. I've checked my doors, trunk, and hood but it wasn't the case.
Old Sep 11, 2006 | 07:51 AM
fcm's Avatar
fcm
Old Fart
I would have a look at the wiring for the alarm, check the unlock output, [make sure it's still connected] Did you add door locks or did the car already have power door locks?
Check the green/white hood/trunk input, [make sure it is not shorting out to ground] also is it connected to both the hood and the trunk/hatch? 94
PS, does the alarm work, will it trigger if you open a door or hood/trunk, does it first stage give warning? 94
Old Sep 13, 2006 | 06:15 PM
Mysterious's Avatar
Default Re: Alpine alarm? (fcm)
I've checked everything and everything is still connected and the alarm still work but not like before. The siren does not go on for like 30 seconds or so. It goes on for like 1 second, then it pause, then goes back on.
Old Sep 14, 2006 | 10:14 AM
fcm's Avatar
fcm
Old Fart
OIC Sounds like she got into programing, she has changed siren output to horn output, although I am not sure how she did that without the key and valet/program switch
You will have to go into programing to change it back.
Do you have the install manual? 94
Old Sep 14, 2006 | 08:39 PM
Mysterious's Avatar
I need the manual. I've tried the alpine website but they don't have the alarm section.
Old Sep 14, 2006 | 09:01 PM
JDMREDEG's Avatar
ive been in your spot before
Old Sep 15, 2006 | 08:27 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mysterious &raquo;</TD></TR><TR><TD CLASS="quote">I need the manual. I've tried the alpine website but they don't have the alarm section. </TD></TR></TABLE> Yes they do, sorry I can't link you directly but this is what you do click "Support" at Alpine.com, then "0wners Manuals and Wiring Diagrams", then "Continue without login" then type in SEC-100S exactly like that in the Quick Search box both the "Installation Guide" and the "Owners Manual" are there a PDF files, the show up as
1- SEC-150R/SEC-100S installation guide
2-SEC-150R/SEC-100S Owners Manual
The 100S and 150R are identical except the 150R also has a dual stage radar. 94
DCFIVER
Acura TL, RL & ZDX
Mar 28, 2011 06:07 AM
Wazup
Audio / Security / Video
Nov 16, 2009 11:47 AM
Coke in a Can
Sep 23, 2007 11:37 PM
Nameless Warrior
17
Feb 24, 2007 08:42 AM
devilpuppy
Nov 15, 2004 12:46 PM
