Suspension & Brakes Theory, alignment, spring rates....
aftermarket wheel bearings
Old Jun 22, 2005 | 11:16 PM
eda6's Avatar
Default aftermarket wheel bearings
It's time to replace my front passenger wheel bearing.
I'm using EF9 knuckles that require DA9/DB1 wheel bearings.
New wheel bearing from acura costs $115.
Found some Koyo wheel bearings for half the price.
Are aftermarket wheel bearings quality replacements? or Should i go with oem?
Just trying to do this right the 1st time. Thank You
Old Jun 23, 2005 | 07:31 AM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: aftermarket wheel bearings (eda6)
If it's the same Koyo company that I'm thinking of (radiators etc...), they make tons of parts for Honda. Chances are they could be the very same parts, just sold directly from the original manufacturer...
Old Jun 23, 2005 | 07:35 AM
94eg!'s Avatar
#1 Super Guy
Loved
Here is a good deal on the part directly from an Acura dealership...
http://www.acuraautomotivepart...y.jsp
Old Jun 23, 2005 | 04:33 PM
eda6's Avatar
Default Re: aftermarket wheel bearings (94eg!)
Thanks for the link.
Can I use a ball joint press to install the new wheel bearing? If not, do you know of a good shop in the las vegas area with a press?
Old Jun 23, 2005 | 09:09 PM
94eg!'s Avatar
#1 Super Guy
Loved
This is the only place I've found that would press bushings out/in for me. The charge $10 a bushing to remove/replace, so it should cost about the same if you could get the hub off. If not they may charge you more...
Charleston atuo parts
Scott53092
Mar 23, 2011 07:30 AM
avio
Dec 20, 2010 08:16 AM
ketchup
Mar 10, 2008 06:06 PM
itr1235
Aug 25, 2004 04:58 PM
