Clutch problems
Old Jun 22, 2005 | 11:07 PM
headrec*'s Avatar
Default Clutch problems
Hey
I have a 1985 Honda Accord SE-i. It has a cable clutch and today I was driving it and all of the sudden when I pushed in the clutch and it got a lot softer and after that the clutch was slipping everytime I would give it enough gas to try and get some power to the ground. I can drive it around normally but as soon as I try to get some power out of it the clutch just starts slipping.
Basically the clutch is now not fully engaging the transmission and engine. It probably isn't a bad clutch only because it's fairly new, I don't beat on it, and it happened all of the sudden.
I discovered the clutch cable was kinda messed up (hard to explain) but I fixed what was apparently wrong with it and it still has the same problem. It could still be the cable but I highly doubt it. What would cause the clutch to not fully engage like this?
I'm thinking maybe something internally is wrong but I really don't know. Any suggestions?
Old Jun 23, 2005 | 08:39 AM
headrec*'s Avatar
Default Re: Clutch problems (headrec*)
C'mon guys. A little help please!
Old Jun 23, 2005 | 10:07 AM
headrec*'s Avatar
Okay. I went out and removed the clutch cable thinking maybe that it wasn't letting the clutch fork fully release the TOB but as it turns out the clutch still slips when I try to get power out of it.
This leads me to believe that the clutch has checked out BUT I still don't understand why this would have happened all of the sudden like this. I had never had problems with it slipping or even acting up before this happened yesterday.
BEFORE i go and remove the tranny (probably tomorrow) I would like to maybe get some ideas of what to check for before I remove possibly saving me a weekend and a few bucks. Thanks in advance.
Old Jun 24, 2005 | 09:59 AM
headrec*'s Avatar
Wow you guys are a lot of help .
danno33
12
Sep 30, 2012 08:46 PM
danno33
Jul 14, 2009 07:45 AM
MichealSenior
Feb 17, 2009 12:56 AM
djsire
Sep 7, 2005 04:14 PM
DroppedTegLS
Sep 28, 2002 01:51 PM
