JDM Front End help.
Old Jun 22, 2005 | 10:31 PM
kim_2_da_chee's Avatar
Default JDM Front End help.
The headlights for this is a one-bulb headlight. Where / which kind of bulb do I buy? (needs to emit normal and highbeam lights) How in the world do I hook up the wires?
Side marker lights... do I just splice them in with the corner lamp wires?
TIA
Old Jun 22, 2005 | 11:37 PM
ukdm crx's Avatar
Default Re: JDM Front End help. (kim_2_da_chee)
You need h4h bulbs and to wire them up you just match up the same colored wires, sidemarkers nshould be spliced into the bumper light wires, they should only come on when your turn signal is on.
Old Jun 23, 2005 | 01:08 AM
dh's Avatar
dh
Default Re: JDM Front End help. (ukdm crx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ukdm crx &raquo;</TD></TR><TR><TD CLASS="quote">You need h4h bulbs and to wire them up you just match up the same colored wires, sidemarkers nshould be spliced into the bumper light wires, they should only come on when your turn signal is on.</TD></TR></TABLE>
Old Jun 23, 2005 | 02:35 AM
K20EF8's Avatar
Hey im in Toronto and on TCC, US cars are different( I thnk), both corner lights dont do anything even when u signal so just use one bulb and ignore the other one, as far as the headlights go take the ground from the high and low beams and combine them, u should now have 3 different coloured wires, one of them being the ground ie black, thats all it takes. As far as bilbs are concerned you can order them online from a # of sites
icbmotorsports etc etc
Old Jun 23, 2005 | 09:32 AM
Default Re: (CRX4u2NV)
Cool thanks guys
whiteej1
Sep 15, 2006 05:10 PM
iHOPEyouCHOKE
Mar 17, 2006 06:55 AM
idriveadelsol7
10
Jun 19, 2005 09:18 PM
Dc2 Powered
Aug 22, 2004 05:50 PM
FusionITR
Sep 9, 2002 07:24 PM
