HEADERS ON B16 2ND O2?
Old Jun 22, 2005 | 09:14 PM
KURUPTinc's Avatar
Default HEADERS ON B16 2ND O2?
HEY IM PUTTING HEADERS ON A B16 WITH A PR3. IT CAME WITH TWO o2 SENSORS AND OBVIOUSLY IT ONLY HAS ONE PLUG ON THE HEADERS FOR THE O2 SENSOR. WHAT DO I DO ABOUT THE 2ND ONE?
Modified by KURUPTinc at 10:30 PM 6/22/2005
Old Jun 22, 2005 | 09:46 PM
KURUPTinc's Avatar
Default Re: HEADERS ON B16 2ND O2? (KURUPTinc)
SO DOES ANY BODY KNOW?SHOULD I JUST RUN IT LIKE THAT OR WHAT?
Old Jun 22, 2005 | 09:54 PM
PURPLETERROR aka BIGMATT's Avatar
depends on how many headerz u gots
Old Jun 22, 2005 | 10:01 PM
KURUPTinc's Avatar
Default Re: HEADERS ON B16 2ND O2? (PURPLETERROR)
4-2-1 EXHAUST MANIFOLD. IS THAT BETTER
Old Jun 22, 2005 | 10:37 PM
kim_2_da_chee's Avatar
You can take the header to an exhaust shop and ask them to drill the second hole and weld in the bung for the other O2 sensor.
Old Jun 22, 2005 | 10:43 PM
Jdm90crxdxb16's Avatar
Default Re: HEADERS ON B16 2ND O2? (kim_2_da_chee)
rip that green plugged wire outta there and jus use one (say **** it like i did)and take the check lite bulb out if u cant tell somthins wrong with the motor u should buy a saturn and take it to a mechanic when the check light comes on
Old Jun 23, 2005 | 01:15 AM
dh's Avatar
dh
Default Re: HEADERS ON B16 2ND O2? (Jdm90crxdxb16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jdm90crxdxb16 &raquo;</TD></TR><TR><TD CLASS="quote">rip that green plugged wire outta there and jus use one (say **** it like i did)and take the check lite bulb out if u cant tell somthins wrong with the motor u should buy a saturn and take it to a mechanic when the check light comes on</TD></TR></TABLE>
Yeah my CEL always pops up for my o2 sensors...I just said one day, whatever and stopped turning it off, and now it's been on for a while, but I don't even notice it anymore. But like he said, if you don't know when your cars not driving right, you shouldn't be tinkering with it.
Old Jun 23, 2005 | 07:36 AM
d357r0y's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kim_2_da_chee &raquo;</TD></TR><TR><TD CLASS="quote">You can take the header to an exhaust shop and ask them to drill the second hole and weld in the bung for the other O2 sensor.</TD></TR></TABLE>
Old Jun 23, 2005 | 07:47 AM
Honestly man, dont ever give anyone advice on their car, stick to reading and learning.
For the original poster here are a few links
https://honda-tech.com/zerothread?id=274113&page=2
https://honda-tech.com/zerothread?id=317499
Old Jun 23, 2005 | 09:05 AM
Autoworks's Avatar
sucks for you
I had a second bung welded in my collector exactly like the hasport header (I used a LS 4-2-1 that already had one bung in it)
Old Jun 27, 2005 | 08:33 PM
KURUPTinc's Avatar
Default Re: HEADERS ON B16 2ND O2? (Autoworks)
How bad would it run if i just wired both wires together?
Old Jun 27, 2005 | 10:01 PM
KURUPTinc's Avatar
would it run rich?
Old Jun 27, 2005 | 10:29 PM
Bunger's Avatar
Don't wire both wires together, it can cause 2 of the cylinders to run rich and the other 2 lean, either convert to OBD-1 or weld a 2nd o2 on, but the first has to be welded in the correct place also. If I remember correctly, one O2 is for cylinders 1 and 3... and the other, well I think you can figure that part out.
Old Jun 28, 2005 | 12:13 AM
NikoZai's Avatar
and a day or two later .. he was banned LOL
Have exhaust shop tap for second O2 sensor. You need both to run correctly.
Modified by NikoZai at 1:23 AM 6/28/2005
Xxcivic97xX
Aug 4, 2010 08:23 AM
SiR Inspired ED7
May 15, 2006 05:51 PM
christianscrx
Mar 11, 2005 11:40 AM
shadowstylz
Sep 3, 2003 07:07 PM
T_Rex
40
Oct 29, 2002 12:27 PM
