What cams to boost my gsr?
Run the stock GSR cams until you have built the block and are ready to turn the boost up. They will give you the best overall power at low to moderate boost.
My engine is used to i'm going to get new cam seals at least. Before Boost I was wandering if I only upgrade fuel and pistons/rods would I be ok to boost. Or do I need to change my valve and springs also
