need help with hooking up the obd1
Old Jun 22, 2005 | 08:08 PM
89crx1184's Avatar
Default need help with hooking up the obd1
okay... so i bought an engine from a friend of mine the engine is d16z6... so for me to put it on my crx si i need to change to obd1... wat do i need to do... my money is really tight rite now... so im sure if i could afford the obd0-obd1 conversion kit which cost like $200... can any one tell me how i can do it cheaper... maybe like make my own conversion kit... thanks guys...
Old Jun 22, 2005 | 11:10 PM
NikoZai's Avatar
Default Re: need help with hooking up the obd1 (89crx1184)
the ecu conversion harness is around $100 and money well spent, you don't even want to try to make that or hack up your ECU wiring.
The VTEC subharness and O2 wiring you can do yourself, just need to solder wires is all.
Old Jun 24, 2005 | 01:23 PM
89crx1184's Avatar
he is giving me his harness... do i stilll neeed to do that conversion
Old Jun 24, 2005 | 03:14 PM
NikoZai's Avatar
Default Re: (89crx1184)
he's giving you an engine harness or a ECU jumper???
You do not want to use the engine harness that came with the z6, it wouldn't work on an OBD0 car.
Old Jun 25, 2005 | 06:29 AM
89crx1184's Avatar
he is giving me engine harness and his ecu
Old Jul 5, 2005 | 06:13 AM
89crx1184's Avatar
does anyone know if i have engine harnessfrom z6 with the ecu do i still need the conversion harness...
Old Jul 5, 2005 | 07:24 AM
Rywire's Avatar
Yes, dont try and use a z6 harness, its WAY too much work, and you might not ever get it right man.
Trust me, i do honda wiring for a living....
Ryan
Old Jul 5, 2005 | 08:20 AM
Setsuna F Seiei's Avatar
Honda-Tech Platinum Member
Default Re: (droppedcrxsi)
dizzy harness (not necessary if you;re lazy to repin wires), obd0-obd1 jumper/conversion harness, VTEC sub harness (not necessary) PM Nikozai, he's the only one I know who carries complete harnesses for these kind of swaps.
Old Jul 5, 2005 | 11:38 AM
NikoZai's Avatar
Default Re: (BrokeAssPinoy)
You can't re-pin the 2-pin round connector at the distributor, you would have to cut and solder.
We do sell complete OBD1 conversions instead of all the pieces.
And if you want it done right, you can even send us your harness and we'll pin on everything you need. Plus we cut and crimp factory honda pins on those connections that the pins change on like that 2-pin dizzy plug.
Old Jul 5, 2005 | 02:58 PM
Default Re: (NikoZai)
oh lol yes splicing and soldering is what I meant and to rywire
Old Jul 6, 2005 | 06:12 AM
89crx1184's Avatar
thanks guys... i guesss im just gona go and buy the conversion harnesss.. thanks mike...
Old Jul 6, 2005 | 10:12 AM
DohcVtecCrx's Avatar
Damn can't you guys just keep it tech and not use this as a personal "buy my parts" commercial place?
Don't forget Boomslang, you don't have to fix them, that is what is running in my 13.2 second ef hatch.
You want to use the wiring harnesses from your car dude.
Old Jul 7, 2005 | 01:20 AM
Rywire's Avatar
Default Re: (DohcVtecCrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DohcVtecCrx &raquo;</TD></TR><TR><TD CLASS="quote">Damn can't you guys just keep it tech and not use this as a personal "buy my parts" commercial place?
You want to use the wiring harnesses from your car dude.</TD></TR></TABLE>
Were just helpin the guy out, Peter and I's first few posts were pureley informational.
avaldez
Jun 24, 2009 12:59 PM
trip-doh
Jan 19, 2009 03:08 PM
cdndna
Feb 6, 2006 09:47 AM
quaker
Feb 20, 2004 12:24 PM
