About an Greddy Type S BOV
I read somewhere that the type S BOV should only be used for low boost Settings,like 8psi,could this be?i have ran mine up to 13-14psi and it seems to work fine,what's the highest anyone has used the type S without it surging or losing boost,also Greddy use to make a stiffer spring for it but now they dont,anyone know if there's an company making an aftermarket replacement for that stiffer spring?
greddy rates the type S up to 18psi i think. my friend with a DSM runs 25psi on his type s. i have seen stiff replacement springs for the type s, but i'm unsure if you can use a stiff type R spring in the type S since the type R is larger.
