NE1 using the ats fd without gsr 5th gear?
Old Feb 12, 2002 | 01:47 PM
ITR-01-0977's Avatar
New User
Default NE1 using the ats fd without gsr 5th gear?
I'm trying to find out if anyone uses the ats 4.9 fd with the stock itr gearing....I was wondering if it is decently streetable with out using the gsr 5th.....I will not be doing a whole lot of freeway driving since I'm moving right down the street from work. I talked to Dave at R+D and we both agree that the jdm fd would be fine but the ats may be pushing it a bit....any suggestions?...opinions
Old Feb 12, 2002 | 01:50 PM
Black R's Avatar
25 Year Member
Default Re: NE1 using the ats fd without gsr 5th gear? (ITR-01-0977)
*raises hand*
It's fine. I wouldn't change a thing in retrospect.
Be careful, though: somebody's gonna tell you to do a search soon..... I can feel it.
Old Feb 12, 2002 | 01:54 PM
Austin's Avatar
Default Re: NE1 using the ats fd without gsr 5th gear? (Black R)
*raises hand*
Do a search....hehehe...couldn't help it.
[Modified by Austin, 2:54 PM 2/12/2002]
Old Feb 12, 2002 | 01:56 PM
B18CXr's Avatar
what ever you do
DO NOT INSTALL THE GSR CRAP!!!
Old Feb 12, 2002 | 02:09 PM
Hybrid ctr's Avatar
Default Re: NE1 using the ats fd without gsr 5th gear? (fuzznuts)
Just say NO to
GSR 5th gear
Old Feb 12, 2002 | 02:17 PM
FAST4DR's Avatar
Default Re: NE1 using the ats fd without gsr 5th gear? (B18CXr)
Mark,
As I said on the phone, it is all subjective. Streetable for some is not streetable for others. I would not mess with the 5th gear either way (JDM or ATS). Thanks, talk to you thursday.
Old Feb 12, 2002 | 03:31 PM
TODAwhore's Avatar
Default Re: NE1 using the ats fd without gsr 5th gear? (FAST4DR)
GSR 5th stay with your stock gear...
Daniel who wants to upgrade to the 4th&5th US spec gears w/ats
Old Feb 13, 2002 | 05:44 AM
Dr Pooface's Avatar
Default Re: NE1 using the ats fd without gsr 5th gear? (SpoonDeg)
GSR fifth= waste of money IMO.
The only reason to get one is to raise top speed over 230kph, as the rps are only 500 higher with the ATS so highway cruizing is not much louder than stock. Who needs to go that fast?
Old Feb 13, 2002 | 06:15 AM
Black R's Avatar
25 Year Member
Ditto on the first part, and uh..... already done on the 2nd part.
96 spec 1-5 and ats final = Woohoo! FUN
Old Feb 13, 2002 | 07:02 AM
EleanoR's Avatar
Why is having the GS-R 5th gear such a bad thing? For my application it is perfect. I do highway driving every day to and from work and i like to save money in gas. I do notice a drop in power shifting into 5th gear but if i am redlining my car who needs to go faster than 110 (top speed in 4th gear)??? I mean having it isn't all the bad. If all you do is road race your car and you get to speeds well above 100 mph then yeah stick with the stock 5th gear for more acceleration on the track. Oh well just my .02
BTW mine is the JDM 4.785 not the ATS
Old Feb 13, 2002 | 08:40 AM
B2FiNiTY's Avatar
Default Re: NE1 using the ats fd without gsr 5th gear? (talkie25)
I rather have the lower RPMS in 5th. I don't really need the crazy acceleration in 5th cause I only use it to cruise the streets and freeways. I'll be getting a GSR 5th with the JDM final.
Old Feb 13, 2002 | 08:43 AM
New User
Thanks for eveyones replies.....it looks like I'm going to do the ats with the stock 5th gear......
Old Feb 13, 2002 | 08:50 AM
1GreyTeg's Avatar
Ha Haaaaa, another convert...
TRUST me, you'll love it! Now ya just gotta pick a light weight flywheel to round it all out.
A.
Old Feb 13, 2002 | 08:55 AM
1GreyTeg's Avatar
Default Re: NE1 using the ats fd without gsr 5th gear? (B2FiNiTY)
Why?
a GSR 5th with a JDM final? That just sounds silly to me. And yes I do understand your concern with RPM but, the JDM FD doesn't require the GSR5th to be bearable. I could maybe understand the GSR 5th and the 4.929 but Not the JDM FD. And the ATS is most certainly tolerable and loads of fun on all roads.
Just curious, but have you driven a car yet with either the JDM or ATS FD? If not, you really should to better understand and appreciate it.
Good luck,
A.
Old Feb 13, 2002 | 08:59 AM
CPR's Avatar
CPR
Default Re: NE1 using the ats fd without gsr 5th gear? (1GreyTeg)
I too have plans of getting the JDM FD. To decide if I should go for the GSR 5th, I did some testing. I cruised in 5th gear with the RPMs at 4500 (speed was around 85mph) and it didn't sound that much louder than cruisng at ~4100 rpms. So I'm skipping on the GSR 5th. Is this an accurate representation of what the JDM FD is going to be like while crusing at 80mph?
Anyway, it's your car so do what you want.
Old Feb 13, 2002 | 09:00 AM
Black R's Avatar
25 Year Member
jdm 98 spec huh? you should get the gsr 4th too then.....
Old Feb 13, 2002 | 09:02 AM
zijiejijeijrkjk's Avatar
what about a LS fifth gear then?
Old Feb 13, 2002 | 09:16 AM
1GreyTeg's Avatar
Default Re: NE1 using the ats fd without gsr 5th gear? (elements)
Once again I'll link to a VERY useful if not informative tool to figure out what and where different gearing may put you. It's plug-n-play, just add the gear #'s you want and have at it. It may not be the definitive tool to figure gearing, but, it gives you a good idea of what you have and what you'll have if you swap stuff out.
http://www.autocrossing.com/cgi-bin/gearcalc.cgi
Good luck,
A.
Old Feb 13, 2002 | 10:03 AM
Gear ShiftRPM Speed @ 8400 RPM
1st N/A 36.0
2nd 5474 55.2
3rd 5818 79.8
4th 6378 105.0
5th 5418 162.9
RPM in top gear at 70mph: 3611
with itr trans, LS 5th, 4.9 final drive.
i know im going to get made fun of but...i drive to school and home every week,140 miles each way, all highway. doing this for the next full year.
thanks for the link.
Old Feb 13, 2002 | 10:44 AM
Black R's Avatar
25 Year Member
1st N/A 36.0
2nd 5474 55.2
3rd 5818 79.8
4th 6378 105.0
5th 5418 162.9
.....do you fall out of vtec on the 4-5 shift?
Another option is to turn the vtec off while on long trips... Or tune the partial throttle maps for fuel economy.....
Old Feb 13, 2002 | 10:52 AM
i think i may of have mislead you, i was just bench racing.(or bench conserving gas)
UNKNOWN_MEMBER
Aug 8, 2006 09:46 AM
Heisdan
Aug 23, 2004 11:26 AM
xtrafastcivic
Nov 25, 2002 01:00 PM
ITR21
Sep 26, 2002 10:01 PM
36Chambers
Aug 15, 2002 08:25 PM
