how to check engine light code???
Old Jun 22, 2005 | 01:17 PM
drewcandraw's Avatar
Default how to check engine light code???
im a noob and dont even know what to do to check the check engine light...what do i need to buy to check it and where do i go to check ecu...cause i can take my crx to a shop adn they can reset the check engine light for 25 bucks...ehat do u guys think???take it to the shop or try and fix it my self???
Old Jun 22, 2005 | 01:22 PM
EP3_05's Avatar
Default Re: how to check engine light code??? (drewcandraw)
Procedure:
1. Turn the key to on so the dash lights come one
2. Pull the carpet back in the passenger footwell
3. Check the little window in the metal plate under the carpet
4. Count the flashes...1 short flash=1 1 long flash=ten
5. Consult a shop manual or report back here and we will help
Old Jun 22, 2005 | 01:25 PM
CLICC916's Avatar
if you have an obd0 ecu, all you need to do is take off your ecu cover plate by the passenger footwell, and turn your motor to the on position (don't turn on your engine, just make sure your oil light comes on once). the ecu should flash once to tell you its on, then flash again to tell you which number the code is. a short flash is 1, a long flash is 10. so if it flashes: long, short, short, short, short; the code is 14...and you can search for ecu codes on hondatech...an easy way of resetting your ecu code is just pulling the ecu fuse under your hood out for a minute and putting back in and restarting your car...
Old Jun 22, 2005 | 05:25 PM
Default Re: how to check engine light code??? (CLICC916)
thanks guys ima try that in days coming...hopefully i can figure out this problem
Old Jun 23, 2005 | 04:49 PM
how do i take or remove the carpet without cutting it up to reach the ecu???thanks
Old Jun 23, 2005 | 05:14 PM
Mach69's Avatar
Default Re: how to check engine light code??? (91civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91civic &raquo;</TD></TR><TR><TD CLASS="quote">Count the flashes...1 short flash=1 1 long flash=ten</TD></TR></TABLE>
Yes and No. That depends on the ecu. I remember my pm9 and pm6 ecus used to have only short flashes. My p28 ecu now flashes long and short. This leads me to believe that obd1 and newer ecus have short and long flashes while all obd 0 ecus have only short ones.
Also, you can have multiple codes. There could be 5 flashes, then a pause, then 3 flahses, pause, 5 flashes, 5 3 flashes. That means you have a code 5 and code 3.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drewcandraw &raquo;</TD></TR><TR><TD CLASS="quote">how do i take or remove the carpet without cutting it up to reach the ecu???thanks</TD></TR></TABLE>
Start pulling... really hard. I believe i took out a plastic screw or 2, but it was mostly pulling that got the job done.
SolidSpruce
Jul 8, 2023 03:19 PM
Solidis
Apr 8, 2013 04:33 PM
SmogKing
Aug 3, 2006 12:48 PM
Slow
Nov 20, 2002 11:11 PM
