So close to getting my turbo kit finsihed but ran into a welding snag
Old Jun 22, 2005 | 11:57 AM
pro547's Avatar
Default So close to getting my turbo kit finsihed but ran into a welding snag
Well I'm so close to getting my turbo kit finished, all I have to do is get my charge pipes welded together and that is all. I called every where in my hometown to welding aluminum. One place said that they don't do welding pipes b/c its to hard. I even asked him if he could do it anyways and he said that he was afraid to do it. I mean Afraid to weld pipes together how hard could it be? One quote said that it would be a couple hundred. This is ridiculous. No body can weld up aluminum for me. Should I just run with silicon tubing till I go to college in a couple more months and have someone over there weld it or suck up the couple hundred and get it welded together? Or should I scrap the aluminum and get some mild steel Till I can get it aluminum welded?
Old Jun 22, 2005 | 12:28 PM
Thurman Merman's Avatar
Default Re: So close to getting my turbo kit finsihed but ran into a welding snag (pro547)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pro547 &raquo;</TD></TR><TR><TD CLASS="quote">Or should I scrap the aluminum and get some mild steel</TD></TR></TABLE>
This is what i would do
Plenty of places that can hook you up with the right charge piping in mild steel.
Old Jun 22, 2005 | 12:30 PM
pro547's Avatar
I don't want to waste my 150 dollars for my bends and stuff. GREAT News is that I found someone really cloes to my house that does weld aluminum I'm going to his house tomorrow and showing him the pipes
Old Jun 22, 2005 | 02:02 PM
snowseeker's Avatar
Default Re: (pro547)
If you can mark the pipes where they need to be welded together and the pipes fit tight, you can send them to me and I'll weld them for you. Just hold the pipes together and make a triangle with a marker across the joint where the pipes come together than number the pipes to match.
Will be way cheaper.
Crasian's Avatar
goodluck i have heard that welding aluminum is pretty difficult
Old Jun 22, 2005 | 02:03 PM
snowseeker's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pro547 &raquo;</TD></TR><TR><TD CLASS="quote">I don't want to waste my 150 dollars for my bends and stuff. GREAT News is that I found someone really cloes to my house that does weld aluminum I'm going to his house tomorrow and showing him the pipes</TD></TR></TABLE>
Oops, didn't read this.
Good luck with the pipes.
Old Jun 22, 2005 | 06:10 PM
pro547's Avatar
Default Re: (snowseeker)
Dude, your cool. I'm getting the estimate tomorrow and hopes he can do it. I think he might do it for free but I'm not sure.
fireant
Oct 5, 2008 09:37 AM
Tytank7
Jan 28, 2008 06:56 AM
holtzclaw223
May 8, 2007 08:24 PM
The Destroyer
Welding / Fabrication
19
May 9, 2005 01:07 AM
RACEPAK
Oct 16, 2004 02:58 PM
