Suspension Question?
Old Feb 12, 2002 | 12:55 PM
Fightin'Irish's Avatar
New User
Default Suspension Question?
Hi All,
Does anybody have any ideas on why one corner of my car (96 Civic Coupe) is lower than the rest? The rear passenger side looks as if it is sitting lower than the rest - you can actually see the difference in the gap over the wheel. Could this mean that the shock is busted or could it be something else?
Could it be the spring? (which I'm changing very soon)
Any opinions?
Talk to ye soon
Old Feb 12, 2002 | 12:59 PM
MI-4 Fr33k's Avatar
Default Re: Suspension Question? (Fightin'Irish)
...Could this mean that the shock is busted...
That'd be my guess.
[Modified by 2K1CivicEX, 9:59 PM 2/12/2002]
Old Feb 12, 2002 | 01:07 PM
martini's Avatar
I don't see it being the spring.
Go over to that corner of the car, and put your body weight on it (push down).
Then go to one of the normal corners, and do the same. Did the corner that is lower bounce up and down more? If so, it's the strut.
Old Feb 12, 2002 | 01:55 PM
shamoo's Avatar
Will you make something up for me please?
Default Re: Suspension Question? (martini)
Yeah, use that method to determine if it's the strut. I have a question though....did you notice this after you did suspension work (i.e.: installing springs/shocks?) Sometimes if you don't set the perches or the bushings correctly, the car might sit uneven.
Old Feb 13, 2002 | 02:51 AM
New User
Default Re: Suspension Question? (shamoo)
[I have a question though....did you notice this after you did suspension work ]
I haven't done any yet, but I will be next week! I hadn't planned on changing the shocks (struts) as I'm only dropping the car by 30mm - but I guess I will have to change them now!
Any opinions on what shocks are the best value?
I'm using Cobra Performance Springs (european brand)
Thanks.
Etorres325
Suspension & Brakes
Apr 28, 2010 02:03 PM
grilledcheese33
Suspension & Brakes
Oct 8, 2007 05:36 AM
TwoKSiR
Suspension & Brakes
Oct 1, 2006 11:08 PM
MR_Ek4
Suspension & Brakes
Sep 8, 2006 03:34 PM
Jwbetley
Jan 13, 2005 06:57 PM
