Parts list for a boosted b16 block
Old Jun 22, 2005 | 09:05 AM
TheBobFather's Avatar
Default Parts list for a boosted b16 block
Im about to build my block. Let me know if im missing something
Pistons (rings)
rods
sleeves
water and oil pump
edged and balanced crank
oil pan
arp studs
bearings (all)
Old Jun 22, 2005 | 11:50 AM
turbosi03's Avatar
Default Re: Parts list for a boosted b16 block (jnbhonda)
in detail?
you forgot:
-the O-ring for your oil pump
-O-rings for the coolant pipe (goes from water pump to thermostat)
-oil pan gasket
-head gasket
-honda bond for oil pan and pump, etc...
-lube for bearings, etc...
-O-ring for orfice on block deck
-plastigauge to check clearances
-flywheel (and bolts)
-oil squirter plugs or squirters themselves
-dowel pins to line up the head
-paper gasket for the oil pickup
-oil pickup
-windage tray
-just the RIGHT AMOUNT of weed or beer
thats all I can think of off the top...
Old Jun 22, 2005 | 12:28 PM
Default Re: Parts list for a boosted b16 block (turbosi03)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbosi03 &raquo;</TD></TR><TR><TD CLASS="quote">in detail?
you forgot:
-oil pan gasket
-head gasket
-oil pickup
-windage tray
thats all I can think of off the top... </TD></TR></TABLE>
Well thanks..........1 or 2 of thoes things i forgot, but i meant the major componets.
But the last one will never be forgotten. Anyone else care to add?
Old Jun 22, 2005 | 12:44 PM
turbosi03's Avatar
well, the only thing that hasn't been mentioned is the block itself and the main caps/bolts for the crank... oh and I forgot the rear main seal (seal for other side of crank should be on the new pump)...
assuming the wrist pins/clips rings come with your pistons, we just named every single piece that makes up a bottom end...
just to make sure no one else can add anything for a boosted block you might want hose fittings to replace your oil galley plugs for a catch can setup...
and don't forget the last thing on my previous list!
now build that **** and post some numbers
Old Jun 22, 2005 | 02:35 PM
You got it!!
Dikon0901
Aug 25, 2013 01:55 PM
Quickridez_3
Apr 29, 2008 10:30 PM
JokerTypeR
10
Jul 21, 2006 12:56 PM
teler86
May 31, 2006 08:54 AM
baonest
Aug 3, 2002 02:24 PM
