2000 b16a2 motor in to a 94 4 door gsr
can i use all the same gsr stuff expeciall shift linkage like axles is there anything thst i need to know let me know
hey everybody dont jack my logo it orignal but it tight j/k spread that **** out get the word out
Modified by purejdmsi at 3:06 AM 6/22/2005
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by purejdmsi »</TD></TR><TR><TD CLASS="quote">can i use all the same gsr stuff expeciall shift linkage like axles is there anything thst i need to know let me know
Everything should drop in fine and everything mechanical can be used. Will you be using the b16 wiring harness, if not, your gonna have to change a few plugs because of the obd differences
</TD></TR></TABLE>Everything should drop in fine and everything mechanical can be used. Will you be using the b16 wiring harness, if not, your gonna have to change a few plugs because of the obd differences
cause the shift linkage feels like its not right and the rear brackit is too short from the si i think but my main concer in the linkage but thank for all the info
The timing belt side mount and bracket will have to be changed on the motor if it is out of a 99-00 SI
you need the 94-00 teg rear bracket "L" shaped one
linkage is the same
axels are the same
linkage is the same
axels are the same
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Timmay »</TD></TR><TR><TD CLASS="quote">The timing belt side mount and bracket will have to be changed on the motor if it is out of a 99-00 SI
linkage is the same
axels are the same</TD></TR></TABLE>
thank you , finally someone summed it up..
linkage is the same
HELLAnorcal
Nov 28, 2006 06:15 PM
SivikHatch
12
Jul 31, 2004 09:53 AM
