should your car smoke......
Old Jun 21, 2005 | 09:52 PM
boostedeghatch's Avatar
Default should your car smoke......
after installing a freshly rebuilt motor?
i sometimes get white smoke out the exhaust at idle and sometimes if i rev the motor, more smoke will come out.
motor has 275 miles on it so far.
compression is around 210psi across
no loss in coolant
found some oil spots in the IM
Old Jun 21, 2005 | 10:55 PM
snowseeker's Avatar
Default Re: should your car smoke...... (boostedeghatch)
Your rings prolly aren't sealed yet. What fluid did you instal the pistons with? What are you running for oil?
Old Jun 21, 2005 | 10:58 PM
Default Re: should your car smoke...... (snowseeker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by snowseeker &raquo;</TD></TR><TR><TD CLASS="quote">Your rings prolly aren't sealed yet. What fluid did you instal the pistons with? What are you running for oil?</TD></TR></TABLE>
i didn't install the pistons, i had it done by a friend.
non detergent 30w oil
Old Jun 22, 2005 | 07:20 AM
PURPLETERROR aka BIGMATT's Avatar
sounds like your rings haven sealed yet, are you using oem rings or aftermarket. Oem's seal in a very short ammount of time, aftermarket "chrome " rings can take alot longer,.
Old Jun 24, 2005 | 06:01 AM
vtecb20coupe's Avatar
B A N N E D
Default Re: should your car smoke...... (PURPLETERROR)
i'd like to know this as well. just installed a set of hastings for my 82 mm rings. but ****, i only have 32 miles on the motor.
EKB18BPR3
Jul 4, 2007 04:54 PM
Egodestruct
Jun 11, 2004 01:55 PM
tominos
22
Feb 18, 2003 08:55 PM
1fstevo
Dec 29, 2001 01:42 PM
