Function7 LCA's work on 95 gsr with comptech swaybar/tie bar combo?
i was wondering if it would fit because the function7 lcas say if you want to fit honda/acura swaybars you need the endlink kit form them... but the comptech kit comes with endlinks already anyone know for sure? Im going with these lcas because i needed lcas for my type r suspension and i had a 10% off ebay coupon that was staring me in the face
They will fit just fine. They have the exact same mounting points as the OEM LCAs. In fact, the Funtion 7 arms are the only aftermarket LCAs that are designed properly for the regular EG/DC rear swaybar end-links...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94eg! »</TD></TR><TR><TD CLASS="quote">They will fit just fine. They have the exact same mounting points as the OEM LCAs. In fact, the Funtion 7 arms are the only aftermarket LCAs that are designed properly for the regular EG/DC rear swaybar end-links...</TD></TR></TABLE>
so with my F7 EG LCAs and ITR bar should I just use 99 si endlinks?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94eg! »</TD></TR><TR><TD CLASS="quote">Reading ownz you..</TD></TR></TABLE>
Eh, I was in a hurry. My skimming thread skills are not up to par.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bay_707 »</TD></TR><TR><TD CLASS="quote">i was wondering if it would fit because the function7 lcas say if you want to fit honda/acura swaybars you need the endlink kit form them... but the comptech kit comes with endlinks already anyone know for sure? Im going with these lcas because i needed lcas for my type r suspension and i had a 10% off ebay coupon that was staring me in the face
They will work with the Comptech sway bar (and endlinks). You will need a longer bolt + nut because of the wider arm. Our arms are not threaded at the sway bar mount hole to eliminate the possibility of the end user stripping the thread.
-S
</TD></TR></TABLE>They will work with the Comptech sway bar (and endlinks). You will need a longer bolt + nut because of the wider arm. Our arms are not threaded at the sway bar mount hole to eliminate the possibility of the end user stripping the thread.
-S
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94eg! »</TD></TR><TR><TD CLASS="quote">Come on man. I never mentioned anything about the EK civics or their parts. Use the EG/DC end-links...
Actually, the EK links work nicely with our arms with some sway bar combinations, although they do cost about $50 a side new.
Asking questions is free and it beats reading.
Street Ghost
Apr 19, 2004 04:52 PM
Street Ghost
Apr 19, 2004 10:10 AM
95civiccoupe31
Jul 29, 2002 02:34 PM
