oil spots in IM
Old Jun 21, 2005 | 05:31 PM
boostedeghatch's Avatar
Default oil spots in IM
took off the skunk2 intake manifold and noticed some oil spots in there.
i do notice sometimes at ide my car will throw out a little puff of smoke every now and then. sometimes it can be constant, but its very little and hard to tell there is smoke coming out.
motor just got rebuilt with new rings, bearings, etc... motor has 275 miles on it so far.
any reason why there are some oil spots in the intake manifold?
Old Jun 21, 2005 | 05:54 PM
pwr2lbs's Avatar
Default Re: oil spots in IM (boostedeghatch)
If you are still using the factory crank case/pcv (positive crank case ventilation) system then some oil film in the intake manifold is normal. However if it becomes excesive than there may be a problem I.E. too high of crank case pressure due to worn rings, pcv system problems ect.
Old Jun 21, 2005 | 05:57 PM
pwr2lbs's Avatar
Also if you just had the motor rebuilt and only have 275 miles. It may be that the piston rings just have not set/broken in all the way yet.
What type of oil are you running to break in the engine?
Old Jun 21, 2005 | 06:48 PM
non detergent 30w
Old Jun 21, 2005 | 07:06 PM
compression is roughly 210psi across
on the smoke issue, i was told to keep driving it to put more miles on it... since i don't have very many miles on it right now.
Old Jun 21, 2005 | 07:23 PM
pwr2lbs's Avatar
Thats what i would do. And maybee a catch can set up in the future.
j0keefe21
11
Jun 22, 2009 04:20 PM
dc2milanoking75
Apr 8, 2009 10:12 AM
oilguzzler
Mar 7, 2007 08:39 PM
ls-v*2
Feb 16, 2007 07:16 AM
Wazup
May 1, 2003 06:51 PM
