B16A problem
Old Jun 21, 2005 | 05:11 PM
spoonEG6Si's Avatar
Default B16A problem
motor wont rev over 2000 rpm and limiter seems to be there too
Old Jun 21, 2005 | 05:14 PM
Redline130's Avatar
Default Re: B16A problem (spoonEG6Si)
What ecu are you using? Has it been rechipped? Check engine light? Codes off the ecu? Did you set the ignition timing?
Old Jun 21, 2005 | 06:19 PM
Suck my DX's Avatar
Default Re: B16A problem (Redline130)
makes sure all ur sensors are connected properly
Old Jun 22, 2005 | 12:16 AM
OMG B16's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Redline130 &raquo;</TD></TR><TR><TD CLASS="quote">What ecu are you using? Has it been rechipped? Check engine light? Codes off the ecu? Did you set the ignition timing?</TD></TR></TABLE>
If you chipped the ecu, check it for a bad soldering job.
bub113
Dec 22, 2008 04:26 PM
dixonhire
11
Jun 12, 2006 04:27 PM
unknown0001
Nov 9, 2005 03:57 AM
PHILLIPDEEZ
Aug 13, 2005 11:21 AM
TurboRedSi
Jul 17, 2003 10:59 PM
