high O2 sensor output voltage-bad measurement?
Old Jun 21, 2005 | 01:54 PM
duh blacksheep's Avatar
Default high O2 sensor output voltage-bad measurement?
Is it possible to get an O2 sensor votage of over 1 volt?
I get a reading of 1.7 at wot sometimes, and sometimes .15-.25, but usually its at .4. If i keep a constant rev around 3k rpm, its around .35. If the o2 sensor is bad, wouldnt my ECU throw a code, or is it possible my O2 sensor reader is off/mis calibrated?
I'm running a greddy SOHC kit with the blue box.
I'm going to take the kit off next week or the week after to get a smog test, im afraid the o2 sensor is bad and will make my car fail.
thanks
Old Jun 21, 2005 | 06:05 PM
Default Re: high O2 sensor output voltage-bad measurement? (duh blacksheep)
bump
duh blacksheep
Jun 20, 2005 03:07 PM
cu3tip
Oct 18, 2004 09:45 PM
cu3tip
Oct 18, 2004 08:26 PM
boost fed ls
Aug 31, 2004 07:45 PM
