Suspension & Brakes Theory, alignment, spring rates....
Installing Password 3 point bar
Old Jun 21, 2005 | 12:53 PM
DC4_MADMAN's Avatar
Default Installing Password 3 point bar
Do I have to drill holes in the firewall for the 3rd mount location? I did a quick look under the hood and didnt see any real place for it to attach too.
Old Jun 21, 2005 | 01:25 PM
MattD@Stoptech's Avatar
Default Re: Installing Password 3 point bar (4door_demon)
http://www.passwordjdm.com/product.asp?P_ID=752
Old Jun 21, 2005 | 01:46 PM
DC4_MADMAN's Avatar
Default Re: Installing Password 3 point bar (El Pollo Diablo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by El Pollo Diablo &raquo;</TD></TR><TR><TD CLASS="quote">http://www.passwordjdm.com/product.asp?P_ID=752</TD></TR></TABLE>
Helpful, thanks, woulda been nice to get those 2 bolts with the bar though.
Old Jun 21, 2005 | 01:51 PM
They come with the kit....
*shrug*
if you bought the kit used, you didn't get a complete kit
Old Jun 21, 2005 | 01:55 PM
DC4_MADMAN's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by El Pollo Diablo &raquo;</TD></TR><TR><TD CLASS="quote">They come with the kit....
*shrug*
if you bought the kit used, you didn't get a complete kit</TD></TR></TABLE>
Got the 3 bar kit straight from password, just looked in the box and no bolts.
Wouldnt happen to know the size would ya?
Guess I'll send an email to password.
Old Jun 21, 2005 | 02:06 PM
Have you read the directions yet?
The directions are in there, and on the website...and they give you the bolt size.
Old Jun 21, 2005 | 03:41 PM
DC4_MADMAN's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by El Pollo Diablo &raquo;</TD></TR><TR><TD CLASS="quote">Have you read the directions yet?
The directions are in there, and on the website...and they give you the bolt size.</TD></TR></TABLE>
Yeah, it says 12mm bolts. What just go to the hardware store and say I need 2 12mm bolts? How long you think I need?
Old Jun 21, 2005 | 06:13 PM
Pondus's Avatar
No, the 12mm it refers to in the manual is the size of the wrench needed for the hex heads, I think the actual bolt size is 6 or 8mm. Go to your hardware store and check it out which size bolts that have a 12mm hex head. Lengthwise they should be, well, just long enough
15mm should be enough I think.
Old Jun 21, 2005 | 06:36 PM
DC4_MADMAN's Avatar
Default Re: Installing Password 3 point bar (Pondus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pondus &raquo;</TD></TR><TR><TD CLASS="quote">No, the 12mm it refers to in the manual is the size of the wrench needed for the hex heads, I think the actual bolt size is 6 or 8mm. Go to your hardware store and check it out which size bolts that have a 12mm hex head. Lengthwise they should be, well, just long enough
15mm should be enough I think.</TD></TR></TABLE>
Thanks they are the same size as fender attachment bolts, which is what i used(had a few lying around).
Old Jun 22, 2005 | 08:27 PM
polishrifle's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4door_demon &raquo;</TD></TR><TR><TD CLASS="quote">Thanks they are the same size as fender attachment bolts, which is what i used(had a few lying around).</TD></TR></TABLE>
yeah, I called password after I got my bar with no bolts too, they said that any of the bolts with a 10mm head will work, example: bolts holding your headlights on, there are a million of these things on the car. I went to Lowes and got som 8X1 metric bolts (I think they were 8X1), 8 is the shaft diameter size in mm, and 1 is the thread pitch. I can double check the size tomorrow, or do what I did, take one of the bolts out of your headlight and take it into the store with you and see what size nut that fits on, then find a couple of bolts with the same dimentions.
HipHapa-Eg
Suspension & Brakes
Dec 7, 2009 03:44 PM
CRAZY-EG9
Apr 14, 2008 07:12 AM
nextgtr
Oct 13, 2006 04:47 PM
808State
12
Feb 3, 2004 10:55 PM
