Need Help With Turbo Install
I bought a drag turbo kit and am installing it but they didn't send me any diagrams or instuctions for the kit well the part i am confused on is the IC pipeing does any one know where they go TIA for any help.
You can cut/grind and rotate them to look like so:
...but in my case I will be going with two small pusher style fans from the front, so I can't reall tell you what the situation would be with your setup - if you have a stock radiator and fans, etc...
Anyway, HTH!
DP.-
Anyway, HTH!
DP.-
