i need a wiring diagram
yellow-12volts
red-accesory 12 volts
black-ground
orangew/white-illumination
blue-remote turn on
white-postive left front speaker
whitew/black-negative left front speaker
gray-positve right front speaker
grayw/black-negative right front speaker
green-positive rear left speaker
greenw/black-negative rear left speaker
purple-positive right rear speaker
purplew/black-negative right rear speaker
And those are the wires you need to get everything operational.
black-ground
blue-remote turn on
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kcem1 »</TD></TR><TR><TD CLASS="quote">yellow-12volts
black-ground
blue-remote turn on
And those are the wires you need to get everything operational.</TD></TR></TABLE>
This is a standard across all manufacturers except pioneer only has a single output for amp turn on/power ant that is 12v when ever the deck is on
black-ground
blue-remote turn on
