check engine light acting wierd?
Old Jun 21, 2005 | 11:07 AM
civicex_88005's Avatar
Default check engine light acting wierd?
I have a 94 civic ex. I just put a b16a sir II into it with a p30. I used the original wiring harness for it because it was wired for vtec. I got all the sensors hooked up except for the knock sensor becuase the wiring harness doesn't have it. All the vacumn lines are hooked up except for a real small thats on a cylinder on the firewall by the transaxle.
My check engine light is on. I jump the little connector and turned the ignition to II. Once this happens the SRS light flashes and the check engine light blinks once (long), then pauses, blinks again (long), then pauses, then again (long) and again and again forever. My 02 sensor is wired right and my ITA sensor is hooked up.
Can anyone help me with this? Any suggestions? and shouldn't it be throwing a knock sensor code also?
Old Jun 21, 2005 | 11:55 AM
Default Re: check engine light acting wierd? (civicex_88005)
Can anyone help with this, i have been out of a car for 3 weeks and really want to get this done and finished.
Thanks
Leon
Old Jun 21, 2005 | 01:22 PM
TheNasty0ne's Avatar
check that light again maybe it is acting right but your not sure?....
Old Jun 21, 2005 | 01:57 PM
I let it run for about a minute and all ir puts out is
long-pause pairs.
Old Jun 21, 2005 | 02:17 PM
specv5150's Avatar
that CEL is primary oxygen. Do you have the resources to test a different oxygen sensor?
92integraVTECgsr
Feb 27, 2006 10:47 AM
lsvtecdude
Aug 13, 2005 05:24 PM
aphex23
14
May 18, 2005 11:41 AM
TRUTHUGSOULJAH
Nov 6, 2004 01:21 PM
