anyone ever run turbo and nitrous on stock sleeves?
Old Jun 21, 2005 | 10:11 AM
B16Civic93's Avatar
Default anyone ever run turbo and nitrous on stock sleeves?
just curious if anyone runs turbo and nitrous on stock sleeves? if so what is your setup? i'm in the process of a build and i was just thinking of how it would hold up and if it would be hard to tune. nothing big just like a 50 shot on top of the turbo. let me know.
Old Jun 21, 2005 | 11:05 AM
adseguy's Avatar
Default Re: anyone ever run turbo and nitrous on stock sleeves? (B16Civic93)
Sleeves should be changed around 450whp....the number is arbitrary. It's really how much heat and cylinder pressure you are exerting, but no way to determine exactly without a round about HP number. If you are thinking about over 450whp then sleeve it
Old Jun 21, 2005 | 12:12 PM
SOHCD16y8's Avatar
its really all in the tune, someone a few weeks ago hit 530whp on stock sleeves. If you have the money sleeve it, if not just be careful. I personally plan on a 50 shot on my turbo setup only because the systems already in the car fom my old setup so I might as well use it.
Old Jun 21, 2005 | 03:17 PM
B16Civic93's Avatar
Default Re: (SOHCD16y8)
well it will probably have a decently high cylinder pressure, because i have an 18g turbo right now and i plan on running around 18+psi in order to achieve my goal of 300-350whp so i'll have to see how that works out before i will know if i want to put a small shot on it. i was just wondering if it is harder to tune the nitrous when it is being forced in by the turbo.
off topic- what kind of egt temps should forged pistons withstand with stock sleeves?
Old Jun 23, 2005 | 08:47 PM
B16Civic93's Avatar
Default Re: (B16Civic93)
bump
Old Jun 23, 2005 | 11:04 PM
EK FLY's Avatar
DO U THINK U CAN TAKE A B18C1 BORED TO 81.5 WITH BLOCKGUARD FAR MORE THAN 450 ?...
Old Jun 24, 2005 | 12:48 AM
Ls1 FD3s's Avatar
Default Re: (EGSR)
DO YOU THINK YOU CAN TURN THE ****** CAPS OFF....
I plan to dual power adder my stock *** block.
Old Jun 24, 2005 | 04:11 AM
mrbsponge's Avatar
my stock sleeved B16 is still running with dual power adder.............................2 years so far!
Old Jun 24, 2005 | 07:51 AM
B16Civic93's Avatar
Default Re: (mrbsponge)
is it harder to tune the nitrous when it is being forced in by the turbo?
Old Jun 27, 2005 | 03:33 PM
B16Civic93's Avatar
bump
Old Jun 27, 2005 | 03:37 PM
MooreBoost's Avatar
Not really. Tune for the turbo, then spray, and adjust the fuel jet as needed.
Old Dec 17, 2005 | 06:12 AM
boost fed ls's Avatar
Default Re: (MooreBoost)
I ran 12.40 @118.8mph on 9psi and a 75 shot with no problems. This year since I finally got bigger injectors, I am going to be running 18psi+ and a 100 shot on stock sleeves. Once you do both (nitrous and turbo) you will never go back. I love doing things that people say you cant do
Old Dec 17, 2005 | 08:55 AM
H*P*S's Avatar
477 stock sleeves 81.5 x 89 way more than 100 9 to 10,000 rpm pulls/track runs
still screams
93acclude
Jun 28, 2004 07:18 PM
5hif7
Apr 15, 2004 01:29 PM
Legendaryyaj
Nov 18, 2003 02:26 PM
hj
Apr 21, 2003 03:30 PM
valentinecr
Aug 22, 2001 11:12 AM
