Back seats removal...
Old Jun 21, 2005 | 10:05 AM
VTecLude1994's Avatar
Default Back seats removal...
Can anyone help me on how to remove the back seats? I would like to leave the center console in the back where the powered 6x9 is. I'm wanting to pull just the 2 seats out(the bottom and the back)and put 1-10" or 12" in each seat back and then an amp where the bottom used to be in each. For right now I just need some help on how to remove the back seats.
Thanks
Old Jun 21, 2005 | 10:08 AM
MUGEN-CRX's Avatar
Default Re: Back seats removal... (95LudeVTec)
for the rear bottom pieces.. press down on the sides of the seat and then pull that leverage under the seat... after the bottom piece is taken off. there should be a srew 10mm i think for the top.. hope that helps
Old Jun 21, 2005 | 10:57 AM
optikal_blitz's Avatar
there are no screws involved on that top bracket, it just slides out after you get the lower pieces disconnected.
to elaborate on Mugen's comments, there are 2 sprung tabs that pull out once you put pressure on them. Pull the seat cushion up so you can see where you have to press down.
pliskin679
May 23, 2007 06:11 PM
mugenspoongsr
May 30, 2005 08:52 AM
optikal_blitz
Jan 29, 2003 02:09 PM
.Ryan
May 10, 2002 04:55 PM
yellowbuffalo
Mar 20, 2002 03:23 PM
