Manual Steering Rack diffrences? Si, DX, HF?
hey guys, Im currious whats the diffrence between the 3.
Autozone has diffrent part numbers for the diffrent trim.
so there IS a diffrence. Thanks guys.
Not sure bout the HF
The DX is linear rate
the Si Progressive
Any Rack with Power Steering would be quicker, but harder to turn
the Si Progressive
whats progressive and linear mean?
oh, after doing some googling,
according to this
http://www.sportcompactcarweb....ojcrx/
the HF turns quicker?? but do they say that beacuse its just LIGHTER?
according to this
Because of the skinny, low rolling resistance tires it was equipped with originally, the steering on the HF is actually quicker than on the Si.
Thats pretty self explanatory. I wonder if the ratio's are different for the other racks. Good find though, its definetly something to look into.
yeah, DX and HF have the same part number. i always heard HF's had the quickest ratios in particular, but its the same as DX. Si does have the rack cut progressively. I've seen it open.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson »</TD></TR><TR><TD CLASS="quote">progressive means the ratio changes as the distance increases. its not the same throughout.</TD></TR></TABLE>
So would you choose a SI rack, over an DX?
EDIT: Im putting in a b16 in about a week, what would you recomend, for the added weight???
Im also on 15's
Im also on 15's
spettinger
18
May 29, 2003 07:07 PM
