track time
Old Jun 20, 2005 | 11:43 PM
W.O.P.'s Avatar
Default track time
who here goes to any track days, and how and where do i sign up? i know about the safty wiring and removing of head/tail/marker lights, but i just need some direction on how to get on the track. i live in salt lake city utah and know i can go down to vegas. anyone want to have me come down with them sometime? even if i have to drive to cali i will. i want to fine tune my riding skills and not do it through a canyon where i will dissapear if i lay it down in a corner doin 80. i think of myself as a pretty good rider (drag knee), but i have never been on a track. any and all USEFUL info appreciated thanks in advance
Old Jun 21, 2005 | 06:26 AM
backlash's Avatar
Default Re: track time (W.O.P.)
Wow I don't know of any tracks existing out in Salt Lake......but you did mention Vegas so you have two options there, Las Vegas Motor Speedway (LVMS) and Pahrump.
If you looking at going to Pahrump info can be found here http://www.socaltrackdays.com/ bike prep info can be cound here http://www.socaltrackdays.com/TermsPrep.htm
If you looking at going to LVMS you can go here for info http://www.fastrackriders.com/....html bike prep stuff can be found here http://www.fastrackriders.com/....html
There is other info out there, but I don't think (not to my knowledge) that anything is close to the Salt Lake area. I have heard that Pahrump is a blast, especially with their "no session" thing that they do.
Old Jun 21, 2005 | 07:10 AM
Vtec44's Avatar
You cal also try http://www.sportbiketracktime.com
LVMS is a tight small and really fun track. Pahrum adds a few high speed straight and flat sweepers, and flow pretty darn well for a big track.
Old Jun 21, 2005 | 07:20 AM
backlash's Avatar
Default Re: (Vtec44)
These guys also do LVMS. http://www.dialitintracktime.com/
Old Jun 21, 2005 | 08:09 AM
marmaladedad's Avatar
Not all trackdays will require safety wire. The requirements vary from organizer-to-organizer.
Fastrack runs a timely show, but the prices are pretty high. Many organizers run at Spring Mountain Motorsports Park (Pahrump), which is a fun track. There is a great mix of different types of turns and straights.
The "no session" thing can be good, because you can maximize your on-track time. But, you will also be sharing the track with very skilled (and some non-skilled) riders. You might not want to have to deal with ricky-racer passing you up on the inside. Other groups, such as http://www.sportbiketracktime.com/ provide a great time. I've also had a positive experience with Dial It In trackdays.
Modified by marmaladeboy at 9:21 AM 6/21/2005
Old Jun 21, 2005 | 08:13 AM
backlash's Avatar
Default Re: (marmaladeboy)
Anybody deal with sbr trackday? I have a trackday with them this Friday. Dealing with Ken over the phone and email, he is awesome! He is even reserving half of the garage for our group!!
Old Jun 21, 2005 | 09:06 AM
big pete's Avatar
Default Re: track time (backlash)
Heres a list check-off list that I got from a trackday provider:
# Mirrors taped or (preferably) removed
# All glass and plastic lenses taped or removed
# Headlight, tail light and turn signals thoroughly taped, unplugged or fuses removed (i.e. they must not work or else not be visible at all, even when brakes are activated)
# Tires must be in good condition with plenty of tread (where applicable)
# Only DOT pavement or roadracing tires
# All valve stems MUST have caps (preferably metal with integral rubber grommet)
# Wheel weights taped
# Fully operational front AND rear brakes
# Functional engine kill switch on handlebar
# License plate taped or removed
# No glycol-based coolants. Replace coolant with plain water or water with Water Wetter. Most of us live in California: there is no need for anti-freeze here and Water Wetter has better heat-transfer properties (i.e. your bike runs cooler). You can get Water Wetter at almost any motorcycle supply store (Cycle Gear, Road Rider, Zoom Cycles, etc).
water wetter and water is a must since coolant is 10x more slick and harder to clean up than oil.
# Motorcycle and KEYS to your motorcycle if it needs keys. People can and DO forget their key. If you forget your keys we can get a locksmith out, but you're not going to be on the track until at least 11am. So double check that you have the keys in your pocket as you drive away from your house!
# Canopy or some form of shade. You're welcome to use the Thunderhill communal canopies but if you'd like to rest away from where all the action is, get some shade.
# Toolbox. Common tools to perform minor work on your bike (for exmaple, tools to remove your wheels if you're planning on getting new tires at the track)
# Spares kit (if you have one). There's no feeling as bad as doing something minor like tipping your bike over in the pit and having that be the end of your day because you snap a footpeg and don't have a spare
# Ramp(s) to load and unload your motorcycle (but there'll be plenty there).
# Tire pressure gauge
# Tire pump (often a bicycle pump works... check it on your bike at home first)
# An emergency contact sheet to leave in a highly visible location in your vehicle -- just in case. This is especially vital if you're coming by yourself.
# Gas. Your motorcycle uses more gas than you think when you have the throttle wide open.
# Helmet
# Boots
# Gloves
# Leathers
# Back protector. Easy to forget!
# Ear plugs if you use them. We recommend that you do; wind noise causes permanent damage to your hearing and distracts you.
# Duct tape
# Miscellaneous spare fuses for your bike
# Zip ties
# Timing equipment (if you have any)
# Fresh batteries for timing equipment
# Camera
# Cash (for purchasing photos, videos or timing services)
# When was the last time you lubed your chain?
My friend is holding a trackday next thursday (6/30) at Thunderhill Raceway in Willows, CA. $180 two group format. Contact me if you're interested
http://thunderhill.com/
Old Jun 21, 2005 | 09:26 AM
backlash's Avatar
Default Re: track time (big pete)
I would like to hit up Thill, but it's so damn FAR!!!! 585 miles from my house
Old Jun 21, 2005 | 09:38 AM
big pete's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by backlash &raquo;</TD></TR><TR><TD CLASS="quote">I would like to hit up Thill, but it's so damn FAR!!!! 585 miles from my house </TD></TR></TABLE>
come on...do it! Its about a 2 1/2 hr drive for me. Theres going to be a couple rc51's...
Old Jun 21, 2005 | 09:40 AM
all8280bcc's Avatar
not to thread jack but does anyone know of any tracks near jacksonville florida that have track days.
Old Jun 21, 2005 | 10:03 AM
backlash's Avatar
Default Re: track time (all8280bcc)
How far away is Daytona International speedway from Jacksonville?
EDIT:I don't know where you are in Jacksonville, but mapquest your address to this one.
Daytona International Speedway
1801 W. International Speedway Blvd.
Daytona Beach, Fla. 32114
Old Jun 21, 2005 | 10:09 AM
Vtec44's Avatar
Default Re: (backlash)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by backlash &raquo;</TD></TR><TR><TD CLASS="quote">Anybody deal with sbr trackday? I have a trackday with them this Friday. Dealing with Ken over the phone and email, he is awesome! He is even reserving half of the garage for our group!!</TD></TR></TABLE>
Dude, walk up to Dawn (the tiger lady and her blue tiger-striped R6) and tell her James from Sportbikers.Net sent yah. She'll take good care of you for me
Old Jun 21, 2005 | 01:25 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vtec44 &raquo;</TD></TR><TR><TD CLASS="quote">Dude, walk up to Dawn (the tiger lady and her blue tiger-striped R6) and tell her James from Sportbikers.Net sent yah. She'll take good care of you for me </TD></TR></TABLE>
She'll backhand ya if you tell her you know James.
pete - THill!! I wish I could go to this one. Be sure to take lots of pictures to show us the tumbleweeds out there.
Old Jun 21, 2005 | 01:48 PM
Etylorcen's Avatar
http://www.biketweakers.com/tr....html
Here is a list of some trackdays.
Old Jun 21, 2005 | 01:56 PM
backlash's Avatar
Default Re: (Etylorcen)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Etylorcen &raquo;</TD></TR><TR><TD CLASS="quote">http://www.biketweakers.com/tr....html
Here is a list of some trackdays.</TD></TR></TABLE>
That is an awesome list. Good find!! Anyone here raced at Infineon? Looks like a pretty fun track.
Old Jun 21, 2005 | 07:02 PM
big pete's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by marmaladeboy &raquo;</TD></TR><TR><TD CLASS="quote">
pete - THill!! I wish I could go to this one. Be sure to take lots of pictures to show us the tumbleweeds out there. </TD></TR></TABLE>
dont worry, gotbluemilk.com will be there taking pics. There will be another one on 8/16 if you can make it to that. I might be able to find you a ride from SF to Thill if that helps
Old Jun 21, 2005 | 07:15 PM
Ugh, 8/16 is while I'm on vacation. Oh well. Maybe I'll find one in November when it's nice and chilly.
Old Jun 21, 2005 | 09:52 PM
backlash's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by marmaladeboy &raquo;</TD></TR><TR><TD CLASS="quote">Ugh, 8/16 is while I'm on vacation. Oh well. </TD></TR></TABLE>
Sooo what is wrong with that? You being on vacation is a perfect excuse to go!
Old Jun 22, 2005 | 09:37 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by backlash &raquo;</TD></TR><TR><TD CLASS="quote">Sooo what is wrong with that? You being on vacation is a perfect excuse to go!</TD></TR></TABLE>
8/16 is when I'll be on vacation outside of the country.
But I have two more tracks I want to try before the year is over - Laguna and THill. After I cross those two off my list, then I can settle for mastering the local tracks. :D
Old Jun 22, 2005 | 10:13 AM
big pete's Avatar
well, if you socal guys want to go to Thill and don't want to drive the whole distance, I can find you guys rides from SF
LSintegra
Honda Motorcycles
10
Oct 25, 2007 02:04 PM
Brian*
Honda Motorcycles
26
Jul 24, 2007 06:23 AM
SuperKool
Dec 2, 2004 07:01 PM
laughinxxx
Feb 25, 2003 07:21 AM
RATEDR
15
Mar 2, 2002 08:47 PM
