what number rod bearing?
Old Jun 20, 2005 | 09:54 PM
ppfalcon's Avatar
Default what number rod bearing?
ok, i have a d16a6 block and bought some eagle rods,notched it for rod clearance, solid decked it,now i need to buy my rod bearings and my question is for the eagle rods what number rod bearing should i run? I called endyn and they very quickly said #3 but on my stock rods it clearly has #2 on them..
i am not knocking larry or his employees , i just dont want to buy two sets of rod bearings because they didnot hear me clearly or were busy when i called..
suggestions please
Old Jun 21, 2005 | 07:59 PM
ppfalcon's Avatar
Default Re: what number rod bearing? (ppfalcon)
noone has any info on this?
Old Jun 21, 2005 | 08:12 PM
zacdaddy77's Avatar
I'm not a master engine builder or anything but could you not measure the clearances if you don't have the proper tools how about plastagauge
Old Jun 21, 2005 | 08:26 PM
v4lu3s's Avatar
RTFM
you may have ot buy multiple bearings. start with the middle sioze, check cleanraces and see how well it fits then go from there.
Old Jun 22, 2005 | 06:07 AM
Jessm985's Avatar
Default Re: (v4lu3s)
If you're buying the bearing from Honda, I'll say this, for the year that I worked there, every ASE master certified technician used Black bearings. That being said - Honda recommends a certain bearing for use with stock internals. For example - if the crankshaft were damaged and needed to be turned. That would require the use of a different "color" bearing to achieve the proper clearance. Plastiguage, if used correctly can be very helpful in this process. Anywho - If it were me, I'd go with the suggestion from the seasoned veterans at Endyn - but that doesn't mean not to check the clearance on everything. I'd go with whatever Larry suggets as a starting point. If you're interested - I've got a diagram of bearing color code in relation to approximate thickness somewhere around here. If you interested - I can probably scan it for you...
My $.02
dieselwilly
Honda Civic (2001 - 2005)
Nov 23, 2014 03:20 PM
pcguy760
Oct 4, 2011 10:16 PM
bdubnyc
K Series
Aug 9, 2009 04:40 AM
ppfalcon
Jun 21, 2005 09:38 PM
Sonny
Aug 23, 2002 08:06 PM
