compression tested, does #'s look good.
i have already asked before about this but no one really responded. i just wanted to see where everyones compression is at with similar mods or comp ratios. i calculated my comp ratio and it was like 11.6:1 or something like that.
my ls/vtec mods
- 11.0:1 arias piston
- pr3 head
- ctr cams
did my compressoin test and came out to be
#1 cyl - 235 psi
#2 cyl - 230 psi
#3 cyl - 230 psi
#4 cyl - 230 psi
are they alrite and can you guys tell me if that is were they're suppose to be at?
my ls/vtec mods
- pr3 head
- ctr cams
#1 cyl - 235 psi
#2 cyl - 230 psi
#3 cyl - 230 psi
#4 cyl - 230 psi
My cousin also got 235 across on his 11.5 compression B18c. The thing is, his motor still burns some oil and he is too lazy to do a leakdown. Can the rings still be the cause even with good compression numbers?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 5thgenallmotor »</TD></TR><TR><TD CLASS="quote">Sounds pretty healthy!
heres mines:
270 270 265 265
not too shabby for a motor with 100k+ internally stock.
setup: JDM h22a off an Auto 4th gen prelude, m2b4, AEM CAI, dented up Apex N-1 catback, removed balancer belt.
I let the car warm up to operating temp, pulled out all the spark plugs, then tested at WOT.
did a compression check on my lil bro's d15b7(dx motor) and he got:
215 210 210 215
270 270 265 265
215 210 210 215
dang, thats pretty high comp #'s for a stock internals. i wonder what your compression ratio is?
another question. could my numbers be lower because i have the intake cam gear set at +1 and exhaust cam gear set at -1?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LsVtec92Hatch »</TD></TR><TR><TD CLASS="quote">All compression testers read different. Altitude plays a factor as well.</TD></TR></TABLE>
Agreed, focus mainly on the differences between the cylinders.
pootie.teng
Jun 2, 2005 10:32 PM
