FS: Possibly practically new 57" flat screen hdtv high def sony
Elevate your entertainment experience with the KDP-57WS655 57" High Definition CRT Projection Television. Featuring Digital Reality Creation® MultiFunction Technology and HD MICROFOCUS™ CRT and Lens System, the KDP-51WS655 produces beautiful picture resolution for your viewing enjoyment. The KDP-57WS655 also gives you other features that you've come to expect from Sony, such as MID®-X Multi Image Driver Circuitry, TruSurround™ SRS® Audio Processing and CineMotion® Reverse 3-2 Pulldown Technology. Listen to MP3 audio and view your photos with the built-in Enhanced Memory Stick® Media slot.
• ATSC Integrated Tuner allows the reception of local, off-air digital broadcasts providing the viewing of free, true high-definition network programming without the addition of a set top box or a monthly fee.
• CableCARD™ Slot provides cable subscribers with access to digitally encrypted cable channels -- without the need for a set-top box -- that will enable you to receive not only standard definition but also high definition television. The CableCARD, which is provided by your cable TV provider, is inserted into the TV’s rear panel CableCARD slot. After the service is activated with your cable TV company, the card replaces the need for a separate set-top box.
• Digital Reality Creation® (DRC) Multifunction Unlike conventional line doublers, the DRC Multifunction feature replaces the signal’s NTSC waveform with the HD equivalent, while doubling the number of vertical and horizontal lines. This results in four times the density for quality sources, such as DVD, satellite and digital camcorders. The Video Menu allows you to select interlaced, progressive or CineMotion® output.
• Wide Screen Mode allows you to watch 4:3 normal broadcasts in wide screen mode (16:9 aspect ratio).
• Favorite Channels allow you to set up and select from up to sixteen of your favorite channels.
• Twin View® Picture & Picture Using Multi-Image Driver (MID™-X), Twin View allows you to watch two programs side by side with the ability to zoom in on one picture and listen to the program in the selected window. You can watch pictures from two different sources (1080i, 720p, 480p, or 480i) simultaneously.
• Clear Edge VM™ Wideband Velocity Modulation allows you to select levels to create better separation between an object and its background for clearer edges, greater picture depth and improved overall picture quality.
• CineMotion® technology using the reverse 3-2 pull down technology, the Cinemotion feature provides smoother picture movement when playing back movies or other video sources on film.
• HD Detailer™ Wide Band Video Amplifier has a high bandwidth frequency rating, which allows it to send more video information to the screen, resulting in finer picture quality, especially for HD sources.
• Steady Sound® equalizes volume levels so there is consistent output between programs and commercials.
• Parental Control (V-Chip) allows parents to block unsuitable programming from younger viewers.
• Memory Stick® Viewer allows you to view digital photos (JPEG) and movies (MPEG1) files that are on Memory Stick media on your television.
• Dual Component Video Inputs achieve greater color accuracy than composite and S-Video when connecting to compatible devices (DVD players, VCRs, etc.).
• Optical Dolby Digital Output
• HDMI Interface (High-Definition Multimedia Interface) provides an uncompressed, all-digital audio/video interface between the TV and any HDMI-equipped audio/video component, such as a set-top box, DVD player, and A/V receiver. HDMI supports enhanced, or high-definition video, plus multi-channel digital audio.
Still has warrany, I've probably used it for less then 100 hours...
Best TV I've ever had, wouldn't sell but i need to fix my em1...
pm offers
sony info:
http://www.sonystyle.com/is-bi...70TVs
Modified by QuikJaysun at 8:26 PM 6/20/2005
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EKallmotor »</TD></TR><TR><TD CLASS="quote">Wowww
Nice TV
Good luck on ur sale.</TD></TR></TABLE>
thx, and thanks for the bump
Nice TV
Good luck on ur sale.</TD></TR></TABLE>thx, and thanks for the bump
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by QuikJaysun »</TD></TR><TR><TD CLASS="quote">up before work
Jaysun
Northwest (Sales)
Jun 25, 2005 07:24 PM
