Very bad experience with Knife Motorsports / Knife Fabrication in TX
Old Jun 20, 2005 | 06:33 PM
alpha's Avatar
Default Very bad experience with Knife Motorsports / Knife Fabrication in TX
If a moderator (Rory Breaker, Arturbo, Earl) wants to lock this I am fine with that.
I just got off the phone with Peter Ehler's ex business associate and decided to finally make this thread. If you are reading this apologize for getting a little upset but I hope you know it's not towards or because of you.
It all started back on 11/13/04. I actually purchased all the parts on 11/30/04. I will start with all the private messages from another board.
Well.. I tell ya what.. I can hook you up with a good deal since you are ClubSi guy of course, but you might want to ditch the turbo, too. Eww.. gt32.. the mangled stepchild of some really nice turbos. GT30R is calling your name with its ball bearing yumminess and equivelant flow with much better spool. I'm assuming you would need a manifold, downpipe, and dumptube. What wastegate are you running currently? Is this for AC or not? What vehicle is this going into? B16? b18? etc.. more facts please
The only reason I ask about the gt30r is that I am overstocked on them.. would let one go to you for like.. 890 + shipping if you don't tell any one.. I'll talk to our fabricator today about the manifold and get back to you asap on that..
He actually had two in his "overstock". The $890.00 ended up being more but no big deal. Right?
Well, heres the deal. We are about 3-4 weeks out right now (Standard wait) while I wait for a mandrel machine. I can do the manifold, downpipe, turbo, dumptube, and new oil feed/return for XXXX w/standard ground shipping. Or of course you can pick up the turbo from me for whatever I quoted you before since I don't have that in front of me right now. Ideally in about 3 months we should have manifolds in stock, but with purchasing the company and moving everything around our delay has gone up a bit. Let me know!
I could of only wished they were three to four weeks out at the time. Here we go
The specs can be found on the precision website at http://precisionturbo.net/turb...=3023
The only thing not listed is the turbine a/r because it is acustom cast piece. According to precision it flows the equivelant of a .63 ar and is good for 500 hp. ALl I know is that I hit full boost by like 3500 rpms... or full boost for now which is about 15 psi.
It has the standard e cover and a standard 5 bolt discharge flange as well.
Money order is fine.. i can also take a credit card or bank card if that is easier since I am a business.. its your call
At this point I wanted todo a credit card transaction.
my cell is 512 423 XXXX and my name is Peter. Thats my cell and business line so if I don't answer I'm probably on the phone so just leave a message and I'll ring you back asap. Thanks!
I soon found out not answering was a normal practice for Knife.
yes.. the turbo is a bit lumpy, but it is still there nice and warm. My car should be on the dyno on tuesday so you can getan idea of what kind of power its good for on pump gas at least. Should be fun
Yeah.. its got a gt30r and a 75 shot on it right now held together with an exedy twin disk clutch. We will see how much it puts down on and off the bottle.
heres the manifold:
Took the pictures down.
HEy man. I know i'm impossible to get ahold of, but give me a call on my cell today 512 423 XXXX and we can get this all wrapped up and working on your manifold mwaahaha!! Time to make some power!
Impossible? Very.
Hey man! Most of your order is done! Just waiting on a couple of specific bends to show up to finish it up and shipt it out! I;l try to snap a few pics today for ya
This was on 12/13/04. Nothing was even close to being finished.
That would be the last time I heard from Peter over private messages. Over time I would talk to Peter off/on. It was VERY hard to get him on the phone. He said they were waiting on material to start fabricating again, my order was done, they had to use my turbocharger on "their" race car, etc. Then I couldnt get Peter on the phone at all. I finally got in touch with his now ex business associate. He said he didnt know what the deal was as Peter dealt with that side of things. He had Peter get back in touch with me. Peter said my order was done and being shipped. One week. Nothing. Two weeks. Nothing. What gives? I had to contact his now ex business associate once again. He said he would try his best to get everything finished. Again. Nothing. After this I couldnt get in touch with Peter if my life depended on it. Come to find out his now ex business associate was moving out of his shop because Peter had lied to him and customers using his business's name. After half a year I finally get my exhaust manifold, downpipe and dump tube. Where is my turbocharger? That's right. Peter ordered it, got a wastegate instead. Peter ordered it and it was on backorder. Peter "bit the bullet" and ordered it from ATP. Well ...
Return-path: <Sales@ATPTurbo.com>
Received: from ms-mta-02 (ms-mta-02-smtp [10.10.4.6])
by ms-mss-04.tampabay.rr.com
(iPlanet Messaging Server 5.2 HotFix 2.04 (built Feb 8 2005))
with ESMTP id <0IG800LSIM1H79@ms-mss-04.tampabay.rr.com> for
XXXX@Tampabay.rr.com; Mon, 09 May 2005 15:27:17 -0400 (EDT)
Received: from flmx04.mgw.rr.com (flmx04.mgw.rr.com [65.32.1.49])
by ms-mta-02.tampabay.rr.com
with ESMTP id <0IG8000GQM1H8P@ms-mta-02.tampabay.rr.com> for
XXXX@Tampabay.rr.com (ORCPT XXXX@Tampabay.rr.com); Mon,
Received: from atpturbo.propagation.net
(atpturbo.propagation.net [64.182.11.176])
by flmx04.mgw.rr.com (8.12.10/8.12.8) with ESMTP id j49JQ7Pv014521 for
<XXXX@Tampabay.rr.com>; Mon, 09 May 2005 15:26:56 -0400 (EDT)
Received: from http://www.atpturbo.com (localhost [127.0.0.1])
by atpturbo.propagation.net (8.11.6p2/8.11.6) with ESMTP id j49J7Q013969 for
<XXXX@Tampabay.rr.com>; Mon, 09 May 2005 14:07:26 -0500
Date: Mon, 09 May 2005 14:07:26 +0700
Subject: Re: <<:GT3076RLE>>
In-reply-to: <200505070057.j470vMO25823@atpturbo.propagation .net>
To: XXXX@Tampabay.rr.com
Reply-to: Sales@ATPTurbo.com
Message-id: <20050509140726.M31805@ATPTurbo.com>
MIME-version: 1.0
X-Mailer: WMail 1.64 20020516
Content-type: text/plain; charset=iso-8859-1
X-OriginatingIP: 208.57.109.204 (sales)
X-Virus-Scanned: Symantec AntiVirus Scan Engine
References: <200505070057.j470vMO25823@atpturbo.propagation .net>
Original-recipient: rfc822;XXXX@Tampabay.rr.com
Hello:
I see an open quotation but not an official order. We're still awaiting
payment info from the buyer to make it "a live order".
ATP
> I'm a customer of XXXX that has been waiting for a
> GT3076RLE for sometime now. Peter at XXXX said he bit the
> bullet and ordered the GT3076RLE for me through you all. From what
> he said you all were just waiting for a compressor cover and were
> going to drop ship it to my location. Nothing has shown up. I want
> to see if what he is saying is true. This would help me ALLOT
> dealing with this problem. The drop ship address he would of gave
> you is below. Thank you!
> XXXX Inc.
> ATTN: XXXX
> XXXX
> Oldsmar FL 34677
No dice Peter. I could go on and on with this whole situation but I am at my end. Peter's ex business associate said he is trying to sell Peter's old turbocharger (anyone want to buy a GT3767S) to pay for my GT3076RLE. I have also filed a backcharge but the process date is so old it's highly unlikely it will be approved. I'm going to speak with my lawyer this week to see if it's even worth pursuing Peter over this amount. If not the only thing left todo is for us to take vacation in Austin Texas to see if we can get this matter resolved in person.
I got Peter's new phone number from his ex business associate so I am going to try and call him tomorrow. Not going to be on good terms
Everyone that has done business with me ( https://honda-tech.com/zerothread?id=936892 ) knows I am willing to work with them due to backorders, personal problems, business move, etc.
Modified by 0x64 at 10:52 PM 6/20/2005
Modified by 0x64 at 10:54 PM 6/20/2005
Old Jun 20, 2005 | 06:43 PM
B20TDC2's Avatar
Default Re: Very bad experience with Knife Motorsports / Knife Fabrication in TX (0x64)
where @ in tx is he located
Old Jun 20, 2005 | 06:46 PM
alpha's Avatar
Default Re: Very bad experience with Knife Motorsports / Knife Fabrication in TX (B20TDC2)
From what I know Austin, TX 78759.
Old Jun 20, 2005 | 06:55 PM
B20TDC2's Avatar
try posting this in the tx. thread in the marketplace and see if you can get some help getting this resolved .
Old Jun 20, 2005 | 07:00 PM
braintree's Avatar
I feel your pain. I was in the same situation. However, I'm glad that the "ex-business partner" was more than helpful in straightening everything out. He told he up front about the problems with knife and assured me that his priority was getting it worked out (which he did). Hope it works our for you.
Old Jun 20, 2005 | 07:18 PM
alpha's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B20TDC2 &raquo;</TD></TR><TR><TD CLASS="quote">try posting this in the tx. thread in the marketplace and see if you can get some help getting this resolved . </TD></TR></TABLE>
Thank you. That's a great idea.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by braintree &raquo;</TD></TR><TR><TD CLASS="quote">I feel your pain. I was in the same situation. However, I'm glad that the "ex-business partner" was more than helpful in straightening everything out. He told he up front about the problems with knife and assured me that his priority was getting it worked out (which he did). Hope it works our for you. </TD></TR></TABLE>
I'm sorry to hear that but that's great you got it all worked out I hope I do as well. Thank you.
Old Jun 20, 2005 | 08:34 PM
xsi-t's Avatar
this is messed up i hope it dosnt get sloppy cause lord knows what happens when the law cant help
i hope he just pays up cause 890 is grand theft!!!
Old Jun 20, 2005 | 08:43 PM
el arbi's Avatar
Default Re: (xsi-t)
That's messed up man.
Old Jun 20, 2005 | 10:58 PM
tony1's Avatar
Default Re: (99SiRacer)
Your situation sucks man. Unfortunately, Peter is apparently just one of those types of people. When i worked at Jotech, I ordered him an AEM EMS and injectors when his girlfriend called and placed the order. Never heard from either of them again. I guess i should have made him put a deposit down on it.
alpha
Jul 30, 2005 10:47 AM
alpha
Texas -OK -LA (Sales)
Jul 25, 2005 02:30 PM
alpha
Jun 23, 2005 10:33 PM
Ch33se
Oct 31, 2002 08:48 AM
93LSivic
Feb 20, 2002 06:19 PM
