d-series bearing question!!!!!!
Old Jun 20, 2005 | 06:11 PM
graveltravel's Avatar
Default d-series bearing question!!!!!!
ok, here it goes.
im fixing to build a d engine for my crx.
my bottom end is a d15b7, top is a d16z6 and the pistons and rods im using are from a d16a1 ( 87-88 dohc zc teg). i found a good deal on new d16z6 bearings ( rod and piston ) , and was wanting to know if all d-series bearings are interchangeable. a few guys have told me that they are. im just wanting confirmation. thanx to all replies!!!
Old Jun 20, 2005 | 06:36 PM
sporkcrx's Avatar
Default Re: d-series bearing question!!!!!! (graveltravel)
ehhhh I dont know. The crank journals might be a little wider or thinner between some. Be weary of that.
Old Jun 20, 2005 | 06:41 PM
ok then, are d-series cranks interchangeable?
if so i wouldnt mind putting a z6 crank in the b7 block then. heh.
Old Jun 20, 2005 | 06:42 PM
sporkcrx's Avatar
Default Re: (graveltravel)
I'm not sure, you'll either have to wait for someone who knows or find out yourself if you already have the parts.
Old Jun 20, 2005 | 07:05 PM
well i have everything but bearings and rings.
im waiting to buy the bearings til i get a " true " answer. otherwise i guess ill have to fork out 90 bucks for bearings. the one im contiplating to purchase are 20 bucks. poot
Old Jun 21, 2005 | 02:44 PM
bump
Old Jun 22, 2005 | 02:56 PM
bump
Old Jun 22, 2005 | 03:29 PM
DeadVet's Avatar
I know you can put a a6 crank in a z6 block and vise versa.
Old Jun 22, 2005 | 04:42 PM
SOHCmaster's Avatar
If you dont find answers about the d-series, try at sohchonda.com
Old Jun 22, 2005 | 07:09 PM
well ive been on d-series.org, but theres no sure answer there either.
Old Jun 23, 2005 | 08:13 AM
civic-4-ges's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by graveltravel &raquo;</TD></TR><TR><TD CLASS="quote">well ive been on d-series.org, but theres no sure answer there either.</TD></TR></TABLE>
You have???
I have saw no topic about this from you. Are you sure it was not under another topic???
There are no piston bearings, simply pins. These are interchangeable except some early d16's...
Rod bearings for d16's are all the same, d15's differ depending on year
Old Jun 23, 2005 | 02:34 PM
ya its on there, under build forum, i think. ull see it under " bearing question". so if i get these d16z6 bearings , i should have no problem with my d16a1 rods? right?
Old Jun 24, 2005 | 03:56 AM
EnzoSpeed's Avatar
Hmmm... I have an un-needed z6 crank that's been kicking around in my garage for a year now... Want to buy it?
arland_2004
Oct 29, 2009 11:22 PM
D16SohcVtec
Apr 22, 2008 07:50 AM
DRKSol
Sep 3, 2003 07:38 PM
CimorelliCRX
May 11, 2003 08:51 AM
