Re-honing Cylinder walls?
Old Jun 20, 2005 | 06:09 PM
CptMidway's Avatar
Default Re-honing Cylinder walls?
Just wondering what you guys use to re hone your cylinder walls. I was thinking about getting a flex hone so I can hone the wals on my single cam motor but wasn't sure which one I'd need. Would a 76mm hone work?
Thanks!
Old Jun 20, 2005 | 07:43 PM
Hybrid96EK's Avatar
Default Re: Re-honing Cylinder walls? (CptMidway)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CptMidway &raquo;</TD></TR><TR><TD CLASS="quote">Just wondering what you guys use to re hone your cylinder walls. I was thinking about getting a flex hone so I can hone the wals on my single cam motor but wasn't sure which one I'd need. Would a 76mm hone work?
Thanks! </TD></TR></TABLE>
You would need a stone hone, no harsher then 400 grit. I've heard 600 grit works best.
Old Jun 20, 2005 | 08:33 PM
CptMidway's Avatar
The is the hone I was referring to. http://www.flex-hone.com/Index...s.htm Just wondering if a 76mm hone would work on a 75mm bore. (Which is what a D series motor is right?)
Old Jun 21, 2005 | 11:56 AM
Rocket's Avatar
Default Re: (CptMidway)
Don't forget to ask the folks here how to properly clean the cyl. after you hone.
Old Jun 21, 2005 | 12:10 PM
hybrid_vtec's Avatar
Default Re: (Rocket)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rocket &raquo;</TD></TR><TR><TD CLASS="quote">Don't forget to ask the folks here how to properly clean the cyl. after you hone.</TD></TR></TABLE>
I would like to know!
Old Jun 21, 2005 | 12:17 PM
Hybrid96EK's Avatar
Wash the cylinders with warm soapy water, immediately oil to prevent rusting.
Old Jun 21, 2005 | 12:19 PM
TrackSpeedRacing's Avatar
Default Re: (hybrid_vtec)
Kyoh
Aug 27, 2007 07:16 PM
NA JDM GSR
Oct 9, 2006 07:04 PM
tnord
30
May 28, 2005 07:57 PM
ntegls
Sep 11, 2003 06:22 PM
