throwing code 14
Old Jun 20, 2005 | 05:02 PM
unlimited6986's Avatar
Default throwing code 14 and 20
im throwing a code 14 and 20 on my si motor wut do i do to fix this?
Old Jun 20, 2005 | 05:07 PM
Suck my DX's Avatar
Default Re: throwing code 14 (unlimited6986)
thats for ure iacv...
it is located on the back of ur IM right next to the throttle body...there are two coolant lines that go through it...take it out and see if it is clogged up...
if it is then clean it out and u should be good to go...
if it is not clogged then u should check it for continuity...if it is getting power then u need to replace ur iacv...id say get one from a junkyard because the dealer costs a grip
Mr.Death
Apr 30, 2010 05:51 PM
