How to get better 60 foot times?
Old Jun 20, 2005 | 04:52 PM
wleach11's Avatar
Default How to get better 60 foot times?
Ok it's a 91 hatch will full interior, LS with turbo, Full Race traction bars, ES bushings in the front end, eibach springs (pro kit) and 22 inch slicks. I have a b16 tranny with an open diff. best I've got was a 2.1 Saw my buddy with an EG with stock suspension (130K) pop off a 1.6 on the same slicks with an open diff too.
So first step is a LSD then what?
Old Jun 20, 2005 | 05:04 PM
Redline130's Avatar
Default Re: How to get better 60 foot times? (wleach11)
How much psi are you running in the slicks? What rpm are you launching at?
Old Jun 20, 2005 | 05:08 PM
wleach11's Avatar
Default Re: How to get better 60 foot times? (Redline130)
10 and 12 I 've tried at 3000 and worked my way up every 500 rpms. Best it at about 5500
Old Jun 20, 2005 | 05:43 PM
steronz's Avatar
seems a bit low for slicks. heat 'em up real good, then drop it from real high up.
Old Jun 20, 2005 | 06:13 PM
2point2's Avatar
Default Re: (steronz)
are the slicks really old?
Old Jun 20, 2005 | 06:20 PM
brusk13's Avatar
not getting enough info here? are you spinning your *** off, bogging or what?
Old Jun 20, 2005 | 06:23 PM
Malgerus's Avatar
Default Re: How to get better 60 foot times? (brusk13)
I usually launch at about 7000+ on slicks.
Gotta make sure that the slicks are nice and warmed up, and the Tire Pressure is set pretty low.
Old Jun 21, 2005 | 12:12 AM
GRAND CIVIC's Avatar
Since yo already know that you need a LSD , you should get one first and then go from there. And what trans are you using?
GIZZ - EXV
Mar 30, 2010 07:53 PM
dookieK9
Nov 5, 2007 10:34 AM
calvinPGMFI
Oct 10, 2006 02:18 AM
Slammd Sol
15
Sep 12, 2005 07:34 AM
B20T CRX
Apr 21, 2004 08:01 PM
