Apexi ® Super VTEC AFC-2
Old Jun 20, 2005 | 04:45 PM
hondaaccord94's Avatar
Default Apexi ® Super VTEC AFC-2
i was just wondering if it is worth getting an Apexi ® Super VTEC AFC-2 for my h22a motor will it help me out in any kind of way?i just really wanna lower my v-tec engagment to about 4800 rpm because right now it comes on at 5600 rpm,so if anyone could tell me if it is worth it or not?thanx
Old Jun 20, 2005 | 05:10 PM
-Bionic-'s Avatar
Former Sponsor
Default Re: Apexi ® Super VTEC AFC-2 (hondaaccord94)
How much does it cost?
What are your future plans with the engine?
Old Jun 20, 2005 | 05:50 PM
Default Re: Apexi ® Super VTEC AFC-2 (-Bionic-)
im planning to turbo my car soon.oohh yeah it costs about 330 from apexi.
Old Jun 20, 2005 | 06:23 PM
xbn83's Avatar
Hondata would be better choice for turbo. VAFC 2 is ok for NA.
Old Jun 20, 2005 | 07:23 PM
JDM.Accord's Avatar
Default Re: Apexi ® Super VTEC AFC-2 (xbn83)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xbn83 &raquo;</TD></TR><TR><TD CLASS="quote">Hondata would be better choice for turbo. VAFC 2 is ok for NA.</TD></TR></TABLE>
True, but why buy twice? No need to spend extra money. If you're serious about boosting go with a real engine management
Old Jun 20, 2005 | 07:43 PM
Nick H's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaaccord94 &raquo;</TD></TR><TR><TD CLASS="quote">i was just wondering if it is worth getting an Apexi ® Super VTEC AFC-2 for my h22a motor will it help me out in any kind of way?i just really wanna lower my v-tec engagment to about 4800 rpm because right now it comes on at 5600 rpm,so if anyone could tell me if it is worth it or not?thanx</TD></TR></TABLE>
well, first of all, it's vtec, not v-tec...the vtec afc is what is called a piggy back engine management system...in other words, it reads the signals from the sensors, modifies the signal, and tricks your ecu to run the motor however you have set it up...
i have an original vafc with my h22 setup...by lowering the vtec engagement point, i did make a smoother power band, eliminating the "kick" that vtec gave when it engaged at its stock position...you can also play with the air/fuel ratios, leaning out the motor a little bit to make a little extra power...there are some other neat little displays that read out anything from vtec engagement, to rpm's, to vaccuum pressure...
it's reall up to you though...if you plan on getting a hondata system in the near future, there is no reason to invest in the apexi unit...
Old Jun 21, 2005 | 05:49 AM
twkdCD595's Avatar
Default Re: Apexi ® Super VTEC AFC-2 (Nick H)
had a vafc and replaced it with the hondata s2b / chipped p28...
when your boosting... the vafc setup gets it done, but the tuned hondata setup gets it done right imo.
I wanted to run more boost, have proper timing control, 2 step, etc... and the piggyback just could not cut the bacon anymore.
shop around the classifieds or ebay for a used vafc... I just sold one that was like new for roughly 150.
Old Jun 21, 2005 | 06:37 AM
-Bionic-'s Avatar
Former Sponsor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaaccord94 &raquo;</TD></TR><TR><TD CLASS="quote">im planning to turbo my car soon.oohh yeah it costs about 330 from apexi.</TD></TR></TABLE>
Dont buy it. Use the money towards a Hondata, or a true stand alone unit i.e AEM EMS.
Old Jun 21, 2005 | 09:46 AM
iam7head's Avatar
why you want to lower it? it's not like you are gaining power from it?
if you can get alot of torque/hp if you lower your vtec crossover point, why honda decide to put it above 5k? they could just lower it to 1500rpm and make 200hp per liter, why? because it just doesn't work that way, think of this, how many oil PSI are you getting at 1500rpm, got my point.
people buy vafc to tune and smooth out power curve, it rarely add any horsepower, maybe 5 at the most with all the bolt on you can find.
Old Jun 21, 2005 | 01:52 PM
91 VTEC akkord's Avatar
go get a "VTEC CONTROLER". you can set your VTEC for just about any RPM that you want.
Old Jun 21, 2005 | 01:56 PM
fw190bvi's Avatar
Default Re: (91 VTEC akkord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91 VTEC akkord &raquo;</TD></TR><TR><TD CLASS="quote">go get a "VTEC CONTROLER". you can set your VTEC for just about any RPM that you want.</TD></TR></TABLE>
wow....what a retarded thread.....
lowering teh engagment point alot will do nothing more than lower gas milege.....
Old Jun 21, 2005 | 02:10 PM
-Bionic-'s Avatar
Former Sponsor
Default Re: (fw190bvi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fw190bvi &raquo;</TD></TR><TR><TD CLASS="quote">
lowering teh engagment point alot will do nothing more than lower gas milege.....</TD></TR></TABLE>
S2K2NR
Honda S2000
Mar 24, 2006 10:52 AM
bja2704
Oct 22, 2005 01:01 PM
dogfood
25
Jul 2, 2004 09:23 PM
djay86
Dec 27, 2003 03:39 PM
psyphre
May 14, 2003 08:34 AM
