Suspension & Brakes Theory, alignment, spring rates....
those with L-con traction bars. I need basic adjustment help. clunking sounds
Old Jun 20, 2005 | 02:47 PM
dpine's Avatar
Default those with L-con traction bars. I need basic adjustment help. clunking sounds
I installed the Lcon traction bars on my ef a few weeks ago. when I put them on I adjusted the radious rods as stiff as possible (shortened them). Is this bad for daily driving. I'm looking for some adjustment tips and I am wondering if them being to tight is causing a clunking problem up front when I get on the brakes and when I accelerate. clunking like an axle. thanks for looking.
Old Jun 21, 2005 | 02:18 PM
dpine's Avatar
Default Re: those with L-con traction bars. I need basic adjustment help. clunking sounds (dpine)
bump I need some help.
Old Aug 15, 2005 | 02:50 PM
KiddEng's Avatar
did you ever get that problem fixed? i just picked up a set of L-cons...
let me know how you liked them
Old Aug 16, 2005 | 01:45 PM
dpine's Avatar
Default Re: those with L-con traction bars. I need basic adjustment help. clunking sounds (KiddEng)
they are ok. I think they are a little harsh for a daily driver. just my $.02. I replaced the pass side axle thinking that was it but it wasn't. I think the culpret is the bushings at the shock fork where u install the radious rods. THier set up to me needs to be redisgned because of where they place the radious rod end. There not in the stock location, but for $300 new the quality is great
Old Aug 30, 2005 | 01:41 PM
L-CON1's Avatar
please call (714)366-1711 and i will assist you guys. ask for louie
Old Aug 30, 2005 | 02:12 PM
KiddEng's Avatar
Default Re: those with L-con traction bars. I need basic adjustment help. clunking sounds (L-CON1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by L-CON1 &raquo;</TD></TR><TR><TD CLASS="quote">please call (714)366-1711 and i will assist you guys. ask for louie
will let you know how they turn out when i get them on the car
03_ep3
Sep 25, 2010 04:35 PM
TweedZ
Mar 9, 2009 02:52 PM
LuckyHonda839
Honda Civic (2001 - 2005)
Sep 14, 2007 09:27 AM
95GSRTT
Feb 22, 2005 01:51 PM
