Suspension & Brakes Theory, alignment, spring rates....
Redrill ITR 96 wheel hub from 4x114.3 to 4x100?
Old Jun 20, 2005 | 01:53 PM
EGGTS's Avatar
Default Redrill ITR 96 wheel hub from 4x114.3 to 4x100?
Has any one redrill ITR 96 wheel hub from 4x114.3 to 4x100? I am looking into doing that because I want to keep my wheel (4x100) and use the ITR 96 disc brake since I already have a very nice condition set. Just want to know if anyone did that and do they have any failure problem?
Thanks
BC
Old Jun 20, 2005 | 11:36 PM
d16y8EL's Avatar
Default Re: Redrill ITR 96 wheel hub from 4x114.3 to 4x100? (EGGTS)
redrill's are fooking dangerous mang. i wouldnt.
Old Jun 21, 2005 | 02:32 PM
EGGTS's Avatar
I ask because we see mult pattern on aluminum wheel. I have to take a look into the stress if I did the changes by using some FEA program. I just want to see if there is anyone actually did this modification.
BC
Old Jun 21, 2005 | 06:25 PM
Alchemist's Avatar
They have a tech articel in Honda Tuning. They just used a drill press and an old 4x100 rotor as a template for drilling.
Old Jun 21, 2005 | 08:26 PM
EGGTS's Avatar
Default Re: Redrill ITR 96 wheel hub from 4x114.3 to 4x100? (Alchemist)
Thanks for your info
Old Jun 22, 2005 | 12:58 PM
nonsense's Avatar
I wouldn't worry about the holes themselves, but I would be worried about any possible stress risers that are created by the drilling.
Old Jun 24, 2005 | 10:52 PM
EGGTS's Avatar
Default Re: Redrill ITR 96 wheel hub from 4x114.3 to 4x100? (nonsense)
I model the hub in CAD and ran an FEA. They Stress doesn't change that much but it is hard to model the real scenario. I figure out I just buy new wheels to fit the brake instead risking the chances of ruin the wheel hub if the machining hole is off.
BC
Old Jun 26, 2005 | 09:32 AM
Chris.'s Avatar
Honda-Tech Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGGTS &raquo;</TD></TR><TR><TD CLASS="quote">I model the hub in CAD and ran an FEA. They Stress doesn't change that much but it is hard to model the real scenario. I figure out I just buy new wheels to fit the brake instead risking the chances of ruin the wheel hub if the machining hole is off.
BC</TD></TR></TABLE>
couldnt you reinforce the 4x114.3 holes once you drill the 4x100 holes or even fill them in?
Old Jun 26, 2005 | 11:27 PM
Dancing is Forbidden's Avatar
Default Re: Redrill ITR 96 wheel hub from 4x114.3 to 4x100? (d16y8EL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d16y8EL &raquo;</TD></TR><TR><TD CLASS="quote">redrill's are fooking dangerous mang. i wouldnt.</TD></TR></TABLE>What the **** are you talking about? On the race car we use redrilled ITR rotors day in and day out. Shut the hell up if you don't have real world experience.
Old Jun 27, 2005 | 08:29 AM
MattD@Stoptech's Avatar
Default Re: Redrill ITR 96 wheel hub from 4x114.3 to 4x100? (ih8jdm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ih8jdm &raquo;</TD></TR><TR><TD CLASS="quote">What the **** are you talking about? On the race car we use redrilled ITR rotors day in and day out. Shut the hell up if you don't have real world experience.</TD></TR></TABLE>
rotors are not hubs. do you have re-drilled hubs?
kettle
Old Jun 27, 2005 | 09:46 AM
Default Re: Redrill ITR 96 wheel hub from 4x114.3 to 4x100? (El Pollo Diablo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by El Pollo Diablo &raquo;</TD></TR><TR><TD CLASS="quote">
kettle</TD></TR></TABLE>/drunk
Old Jun 27, 2005 | 03:26 PM
EGGTS's Avatar
I thought about reinforcing it but in order to do it right you need to heat treat and anneal after you fill the hole with weld. Since I do not know the spec for heat treating, I kind of want to stay away with that. Plus welding may distort the hub and may affect the tolerance for the wheel bearing.
BC
DBada FM
Dec 8, 2009 09:44 PM
thareddb
Aug 28, 2008 11:00 AM
