Installing DSM 440's On OBD 0 B16
if your installing dsm 440 injectors on a obd 0 b16 witch already has the resister box...then can you just put the new injectors in...rewire the clips...and your ready to go?? OR do you have to use a different resister box?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF_LSVtec »</TD></TR><TR><TD CLASS="quote">If it's already prewired, then simply replace the injectors...plug and play.</TD></TR></TABLE>
Just make sure you have the map to run the new injectors.
...and you shouldn't even have to rewire the clips.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96-EJ6 B18C »</TD></TR><TR><TD CLASS="quote">
...and you shouldn't even have to rewire the clips.</TD></TR></TABLE>What map do you need to run with these injectors?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rioninja »</TD></TR><TR><TD CLASS="quote">Hes referring to the correct fuel map, not map sensor. </TD></TR></TABLE>
Built B16A
Jul 4, 2004 06:05 PM
What turbo?
