P28 ECU chipping for boost
Does anyone have any first hand experience with this? I'm running a P28 on a sohc vtec.
What are these programs like for boost, say RPT? With a lower vtec engage and stuff.
I can get these for $80.00 canadian so I figure it may be worth it. Or maybe not?
no one has chips for boost, because Honda ECU's can't compensate for them. Unless you have a Hondata or Zdyne setup
retarded to help with detonation problems
(im assuming)...
other than that youre right..stock honda ECU cant read boost.!
hit up eg6ajk he has a few 'boost chips'
[Modified by Giuseppe, 8:49 PM 2/13/2002]
they can increase your fuel and air mixture aswell as some other parameters though which would help until an engine management could be picked up?
I'm just wondering if a program may do more harm than good on a turbo. what would I be looking for though if I were going to pick up a chip for the time being?
the FMU would raise your fuel pressures,
when going with a vortech unit, its pretty much
non adjustable...it 12:1..10:1 etc etc..
a chiped ECU would definitely have altered
fuel and timing maps,
with turbo, you want to retard timing, either
by the ECU, or BTM, or other components,
but i hear stock timing is good till 12 psi boost
hth
hth
