Need Advice on D16Z6
I am new with imports. I just bought a 95 Civic Ex with a D16Z6 (sohc vtec) motor and I am absolutely loving it. Besides having all the belts and water pump replaced, the only thing I have bought for it so far is a AEM short ram intake. Could anybody give me advice on what to start doing to this motor and what parts to buy. Thank You
"Search" is your friend. But i would guess it all depends on what your intentions for the car are? Auto-x, drag, etc. But the next mods should most likely be header (unless your gonna go turbo), hi-flow cat, & exhuast. Jus my $0.02
I also have a D16z6.When i first got it i immediatly put i/h/e.What really woke up the motor was when i took it to get chipped.My advice take it to get chipped.It cost me only 100 bucks which was worth it when i punched it the first time.
personally i'd go with header and exhaust next. if you really want to change the camshaft but dont have the money for tuning, swap it for a d15b cam as it is slightly more aggressive. best bang for your buck would be to go turbo on the d though. gl and be safe
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d15bcoupe »</TD></TR><TR><TD CLASS="quote">personally i'd go with header and exhaust next. if you really want to change the camshaft but dont have the money for tuning, swap it for a d15b cam as it is slightly more aggressive. best bang for your buck would be to go turbo on the d though. gl and be safe
Exactly, you're going to get most power from a turbo and it won't cost that much if you shop around. Just push a safe amount of boost so you don't blow your motor.
</TD></TR></TABLE>Exactly, you're going to get most power from a turbo and it won't cost that much if you shop around. Just push a safe amount of boost so you don't blow your motor.
JSJ EG6
13
Oct 20, 2002 06:14 PM
