F20B-H22A Driver Side Mounting bracket Bolt spacing???? Need some quik measurements
Old Jun 20, 2005 | 10:38 AM
Sille98's Avatar
Default F20B-H22A Driver Side Mounting bracket Bolt spacing???? Need some quik measurements
Ok I got a problem. Well I got the wrong mounts from Haspoirt, so they will be under way shortly. But I went to measure up the Mount for the driver side bracket, and the bolt spacing is wrong. The Hasport spacing is about 3.75" wide, and my F20B bolt spacing is 2.25". So I need a prelude motor bracket, but want to make sure I get the correct one.
I was wondering if someone could measure their spacing of their bolts taht attaches to the mount for me. I cant see there being a difference between an EG and EK as far as the motor mounting side.
*Heres the pics... Sorry for the crappy quality, but I only had my cell phone cam*
Thanks for the help...
Modified by Sille98 at 11:59 AM 6/20/2005
Modified by Sille98 at 12:00 PM 6/20/2005
Old Jun 20, 2005 | 03:17 PM
Sille98's Avatar
Default Re: F20B-H22A Driver Side Mounting bracket Bolt spacing???? Need some quik measurements (Sille98)
bump...
Old Feb 25, 2015 | 08:37 PM
F20's Avatar
F20
Damn I have the same problem did you figure it out ?
Old Feb 27, 2015 | 10:26 AM
Hasport's Avatar
you change the block bracket on the timing belt side to an h22 bracket
Old Jul 23, 2015 | 05:54 AM
Lemonlude's Avatar
I'm doing this swap into a 93 prelude atm. Looks like you got a h22 mount there. Just get a hasport f20b engine mount and it works. The tranny mount and the rear mount are the same as h22 but engine/driver's side is different
Old Jul 24, 2015 | 07:41 AM
h22carpetride's Avatar
You need a engine side bracket from a h22a4. You can run it with 1 bolt. But I don't recommend it.
97hatchb18b1
Nov 1, 2010 05:14 PM
Jimmii
May 1, 2009 04:04 PM
fin781
Feb 28, 2008 05:38 PM
gursh d
Sep 15, 2007 02:58 PM
JDM CTR EK
10
Jun 16, 2004 04:02 PM
