radius rods a camber?
After putting on a custom x-member the passenger side radius rod wasn't able to be tightned all the way down which causes movement in my wheel. Could this effect my camber? I noticed my camber is off now and bad wear on the inside of my tires. They sometimes squel around turns. Can the radius rods effect your camber like this? Or is there another problem. BTW the car has no suspension mods so what else could i look for?
radius rods most directly affect caster, not camber. its all related however as the wheel moves up and down.
if your wheel has play in it, FIX IT! youre saying your wheel wobbles around? thats frickin dangerous man. id be a lot more worried than tire wear...
On in the process of finding another stock x-member. I wont drive the car until the radius rods are solid. But the camber on the car is off while it is at a standstill. I suspect its more than just the radius rods but i just wasn't sure.
endlessdreams
Jun 28, 2007 07:04 PM
Boilermaker1
Mar 8, 2004 12:18 PM
