How can you tell if the walbro fuel pump is a 255lph or 190lph??
I just received mine from Mr.Fuel Pumps and the pump didn't come in a walbro box or anything so i was just wondering how can you tell should there be a specific code in the front? it doesn't say 255 or 190 on it. any help would be great. just want to make sure i got the right one. thanks in advance.
Reggie
Reggie
GSS3** in most cases indicates that its a 255lph fuel pump. GSS2** in most cases indicates that its a 190lph fuel pump. hope this helps. good luck. once again this can be found stamped on the actual fuel pump unit itself.
i noticed this was the 255lph high pressure not the regular 255lph... is this gonna flood my motor with my 450cc injectors. i'm only planning on putting down about 250whp on my b16.
