Oil flow through the oil filter question
Old Jun 20, 2005 | 09:31 AM
John F's Avatar
Default Oil flow through the oil filter question
What way does the oil flow through the filter ?
Does it flow straight up through the centre and drain back down through the edges or the other way round.
If this plate below was fitted to an engine as you see it with the rubber seal touching the block, what hole would the oil come out of first ?
I ask this (and the first question) because if it flowed straight down the centre it would come out the left hole.
Modified by John F at 7:08 PM 6/20/2005
Old Jun 20, 2005 | 09:57 AM
civicross's Avatar
Default Re: Oil flow through the oil filter question (John F)
The oil would come out of the fitting on the right side of the adaptor.
Old Jun 20, 2005 | 10:08 AM
John F's Avatar
Default Re: Oil flow through the oil filter question (civicross)
Old Jun 20, 2005 | 03:12 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by John F &raquo;</TD></TR><TR><TD CLASS="quote">What way does the oil flow through the filter ?
The oil flows in from the outside and out through the center of the filter.
Old Jun 21, 2005 | 01:41 AM
John F's Avatar
So that means it will come out of the left hand side in the picture ! ? ! ?
Can anybody else confirm this please as thats 2 different answers.
Old Jun 21, 2005 | 05:03 AM
civicross's Avatar
Default Re: (John F)
No, the oil flow fills the adapter from the outer ring, and the fitting on the right will have pressure to go to a remote filter or whatnot. The center part is where the oil comes out of the filter, which is connected to the left hand fitting.
Old Jun 21, 2005 | 08:25 AM
John F's Avatar
Default Re: (civicross)
Horizons1
Aug 21, 2008 01:11 PM
lowgman
Apr 21, 2004 04:14 PM
RAS Motorsports
Jul 8, 2003 06:43 PM
h23accordlude
Jun 3, 2002 09:38 AM
h23accordlude
Jun 3, 2002 06:35 AM
