intake install ls crx ?
I have a 90 crx ls obd0 , and i purchased a blox intake manifold for it . My stock intake has a egr on it by the dizzy but not plugged in i heard that just came on autos so im thinking my otor is from an auto .
anyway the problem im running into is where to put two lines ones a coolant from the fitv that has to be eliminated and just loop the coolant line and one is a vacum line which i think is for the egr . but on the intake it has this look in the lower right on the flange
both the hoses that are in question fit right on but they go to the same place and i cant mix them
where that fitting is , it goes into the head where the coolant went from the fitv on the stock intake .
and when i bought a new gasket it has two holes in it one for coolant one for vaccume and they didnt ask if it was for a auto or manual so i dont think that is the problem . but my new intake only has one so its gonna be blocking the hole on the head so what do i do ??? please help me out sorry if im hard to follow tryed to explain the best i could thanks
Damnit, I read your post twice and still don't see exactly what you are asking. Are you trying to bypass the coolant lines on the EACV on the back of the manifold, or the coolant line coming from the bottom of the manifold (lower r corner in the pic)? I had to do all of it on my AEBS, but I am unsure of what you are asking
ok on the stock intake there is a fitting for the coolant line coming from the fitv and then another one next to it which is alot bigger its vaccume line i think its from the egr . well the blox intake only has one fitting with a place to connect two line one big one small . well the whole that it lines up with on the head is for cool;ant , so what do i do with the other hose and the hole in the head for the vacume line will be blocked by the new intake , sorry im trying to mak myself more clear
crxaddikt
13
Jul 5, 2016 11:24 PM
2stroke1971
Jan 21, 2015 01:36 PM
